mico Posted June 12, 2018 Share Posted June 12, 2018 Hi guys I have a really frustrating problem with my r32 gtr. For about 2 years it has been leaking from the rear exhaust side cam cover. I tried other covers and have changed the gasket twice with no change. I use 3bond sealant also I have changed the half moon seal. It' defo coming from the join between head and cam cover but I just can' t stop it leaking it' crazy. Anyone had this b4 ?? Could it be a cracked head even if it's coming from the in between jointhats all I can think of. Just driving me nuts Link to comment https://www.sau.com.au/forums/topic/474260-leaking-cam-cover/ Share on other sites More sharing options...
jmknights93 Posted June 14, 2018 Share Posted June 14, 2018 Have you ensured the surface where the rocker gasket meets the head is flat? Link to comment https://www.sau.com.au/forums/topic/474260-leaking-cam-cover/#findComment-7878216 Share on other sites More sharing options...
mico Posted June 14, 2018 Author Share Posted June 14, 2018 Yes mate I've also tried sealant in the channel before putting the rubber seal. Then push down on my floor tiles to make sure perfectly flat. I have a small mirror I check around after install to make sure the gap is flat. This is about the 20th time I've removed. Link to comment https://www.sau.com.au/forums/topic/474260-leaking-cam-cover/#findComment-7878263 Share on other sites More sharing options...
mico Posted September 16, 2018 Author Share Posted September 16, 2018 Hi just thought I'd let everyone know I fixed this. Maybe can help someone one day although it looks like I'm the only one who has experienced this. It turns out the factory screws bottom out in the head if u don't use the big metal spacers under them. U can't apply enough pressure. I used bits of rubber tube before under the screws without the spacers but it's just not enough pressure. I now used new short screws with washers and allows more pressure to be put. I'm so stupid lol cheers. Link to comment https://www.sau.com.au/forums/topic/474260-leaking-cam-cover/#findComment-7885515 Share on other sites More sharing options...
