Hey guys, i have a 92 GTSt Type M that ive been having some starting issues and after some talking between myself a another mechanic we came to the thought that it may have a stuck open purge valve, alas information is short in english. So why might i have raw gas in this line here?
Its not a lot of gas but enough to be of concern, especially since its infront of the throttlebody?
https://www.sau.com.au/forums/topic/474361-gas-in-strange-places/
That hose supplies air from upstream the throttlebody to the idle control valve at the back of the plenum chamber.  If by "raw gas" you mean petrol, then.....WTF?!  There really shouldn't be any liquid petrol just rolling around in the plenum chamber, let alone finding its way back through the ICV and into that hose.
By purge valve, are you talking about the fuel tank breather system?  If so, there should never be liquid fuel in that either, just vapour.  It would have to be dead cold for fuel vapour to recondense in there.
Well therein lies my problem haha. It was definitely petrol and there was maybe a half teaspoon of petrol in the line.
Ok after digging through every article i could find,  i found out the line is run to the IACV and an air regulator valve. So there shouldnt be fuel in the line, however there is a small vacuum line that runs to the rear fuel pressure regulator.
So i think the rear FPR might be going bad and pumping fuel into the lines off the IACV and air regulator
  • 2 months later...
Not sure if anyone was following this but i removed the fuel pressure damper and replaced it with a fuel pressure regulator adaptor and 90° brass fitting and the car now runs 100% again.
The damper ended up having a ton of fuel in the vacuum line and on the wrong side of the diaphragm.
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
