Hi All,
Been a while since I posted, so I thought I'd give you an update on the Wags. Rego was coming up fast and I couldn't figure out what the big knock in the suspension was so I ended up ordering a set of BC BR's because it seems like the easiest option. Between ordering and them arriving I slipped a couple discs in my back and had to get a mechanic to do the install. After telling him a few times I really didn't want it any lower He set the rear about an inch off full height of the coilovers and levelled the front to match. This is at least an inch lower than it was. I was already scrapping the rear bar getting in my driveway, so I wasn't looking forward getting in the yard, but damn, she looked pretty good.
After beating the exhaust and the rear bar a few times I thought putting a sleeper along the driveway might help and for a couple days it did. Until I went on a bit too much of an angle and kicked the sleeper up.
So um. If anyone has a rear bar going cheap... Otherwise I'm going to have to learn how to fibreglass in a hurry.
  • Sad 2
https://www.sau.com.au/forums/topic/474518-coilover-fun/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
