Sup peeps!
I'm chasing some recommendations, want someone to take a stock R33 RB25 skyline and build a reliable  Rb25/30 build.
I've got the turbo (T51R) and thats it. Will want to run e85, street car setup, so mod plates galore. Any recommend any shops?
Pretty much anywhere in QLD honestly travel isn't hard for a decent bulid. In absolutely no hurry this is a once in a life time thing so I am starting research now.
https://www.sau.com.au/forums/topic/474545-rb30-bulidershop/
T51R (800 or 1000hp variant)? Have you been in a 3.0l with a T51 on it, IMO, for a street car, there are alot of other turbo's that would suit a street car better, not saying it won't be fun, but you won't win any races off the lights.
What drivetrain you looking at?
I had a 25/30 built a few years ago, just on 500hpatw, as long as you have a big budget for all the bits that the torque eats you should be right, plus a brake upgrade, OEM brakes are rubbish, OEM gearbox won't last long, at least a R33 GTR diff bolts straight in.
I would Google some engine building shops and go check out their stuff in person, when I just googled there was 14 in the Brisbane area alone.
I would lay at least 10-15k minimum for them to build the bare long motor.
Here's some food for thought http://www.lewisengines.com.au/rb-nissan/
If you use a tuning shop to do it, they will just send it to one of these joints most likely, and add their 20% or whatever on top, hopefully they don't send it to a mate in his garage to build.
In the end you can get out of it much much cheaper by buying a car that is already built and just give the motor a refresh if needed, either that or your gonna drop a shit tin of money on a car that may have cost you 50 to 60k to buy and build, that is in the end is worth 20k at most, if your lucky, and I mean really lucky.
800hp KAI and yeh I would go the S/H route but I've been burned a few times over but buying "bulit" engines and getting them fixed...and fixed again...and again.  Yeh I already have the car, the turbo. I'm over the whole "bit from here bit from there, do it at home/local shop for cheap" and ending up spending a stupid amount of time wasted by different "professionals" fixing things that break over and over.
Yeh been following Lewis's stuff for years, they still the go to for engines? If thats the case I might just say f**k it and get one of their's and build around it. Weighting up my options.
I know I'll NEVER get my money back on a car, ever, this is just a life long dream to own a nice skyline. It'll be the second last car I bulid to any decent spec, and I know it won't be "streetable" I'm not looking to pick anyone off the lights. I want a top end cruiser.
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
