Sup peeps!
I'm chasing some recommendations, want someone to take a stock R33 RB25 skyline and build a reliable  Rb25/30 build.
I've got the turbo (T51R) and thats it. Will want to run e85, street car setup, so mod plates galore. Any recommend any shops?
Pretty much anywhere in QLD honestly travel isn't hard for a decent bulid. In absolutely no hurry this is a once in a life time thing so I am starting research now.
https://www.sau.com.au/forums/topic/474545-rb30-bulidershop/
T51R (800 or 1000hp variant)? Have you been in a 3.0l with a T51 on it, IMO, for a street car, there are alot of other turbo's that would suit a street car better, not saying it won't be fun, but you won't win any races off the lights.
What drivetrain you looking at?
I had a 25/30 built a few years ago, just on 500hpatw, as long as you have a big budget for all the bits that the torque eats you should be right, plus a brake upgrade, OEM brakes are rubbish, OEM gearbox won't last long, at least a R33 GTR diff bolts straight in.
I would Google some engine building shops and go check out their stuff in person, when I just googled there was 14 in the Brisbane area alone.
I would lay at least 10-15k minimum for them to build the bare long motor.
Here's some food for thought http://www.lewisengines.com.au/rb-nissan/
If you use a tuning shop to do it, they will just send it to one of these joints most likely, and add their 20% or whatever on top, hopefully they don't send it to a mate in his garage to build.
In the end you can get out of it much much cheaper by buying a car that is already built and just give the motor a refresh if needed, either that or your gonna drop a shit tin of money on a car that may have cost you 50 to 60k to buy and build, that is in the end is worth 20k at most, if your lucky, and I mean really lucky.
800hp KAI and yeh I would go the S/H route but I've been burned a few times over but buying "bulit" engines and getting them fixed...and fixed again...and again.  Yeh I already have the car, the turbo. I'm over the whole "bit from here bit from there, do it at home/local shop for cheap" and ending up spending a stupid amount of time wasted by different "professionals" fixing things that break over and over.
Yeh been following Lewis's stuff for years, they still the go to for engines? If thats the case I might just say f**k it and get one of their's and build around it. Weighting up my options.
I know I'll NEVER get my money back on a car, ever, this is just a life long dream to own a nice skyline. It'll be the second last car I bulid to any decent spec, and I know it won't be "streetable" I'm not looking to pick anyone off the lights. I want a top end cruiser.
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
