Hi everyone,
 I am building a track car with my son R33 and we have a problem with the door and boot locks,
The key will not turn in any of the door locks or the boot (did the day before)
 the doors and boot open from the inside and the internal central lock works both lock and unlock.
I have had a new key cut in case of a wear issue but that made no difference.
I have checked all linkages and all appear to be in place.
So in a nutshell locks mechanically appear to work and all ok when operated from inside the car ignition works (same key).
Key will not open any lock from outside.
Any ideas for me to check?
https://www.sau.com.au/forums/topic/474550-r33-all-locks-jammed/
Take a door card off and with the door open use a screw driver to put the door catch in the "shut" position and observe what happens when you operate the locks. Try with the battery disconnected to see if the central locking is playing up.
Thanks Kiwi
I tried that this morning made no difference the additional info is the key wont turn the barrels when connected, I removed the link to one of the barrels and the key turned, put the link back on and problem remains, no key unlock or locking function.
Checked the mechanical movements around the door latches as well with the door cards off, all appear to be working correctly if using inside door latch and boot release also ignition works with the key,
Is there a lockout in the central locking that could jam on ? that would stop a key from working on all locks?
Fixed it myself,
found the barrels were seized up,
fixed by removing them from the doors and taking them apart, cleaning and silicon lubricant. rebuilt and replaced in the doors once the barrels rotated freely... working like new now.
Coincidence all three went at the same time
  • Like 1
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
