Was given these but are un needed. Apparently pulled off an R34 GTT years ago.
I have a Sedan and the parcel shelf appears a bit different so I was unable to test fit.
Looks like it may fit on other models but don't have one around to test. Front fits 100% on my sedan however.
Looking for $300 ono for the pair.
Pickup Greensborough/Box Hill/Wantirna upon appointment.
https://www.sau.com.au/forums/topic/474815-cusco-front-rear-strut-brace-r34/
Yep - Happy to split. I was looking at more the "rear" one being thrown in with the front one as im not 100% sure it will fit. Turns out it was an S13 front one and I gave it to a mate.
I'd be chasing say $80 for the R34 front one. Yes it fits an R33, I actually have an R33 one on my R34 at the moment!
Inbox me if keen
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
