Precision 6266,Trust T78-29D,NPC push clutch,BPP fuel rail,32 N1 bootlips,Turbosmart FPR800 fuel reg,R32/R33 GTR blow off valves,GTR front diff centre,1000cc injectors
For sale is a lot of new and used RB26 and GTR parts that need to go. Got way too much stuff and don't have the space. Photos will be updated regularly (and tell me if I've forgotten to upload something). All used parts in good condition - I am a hoarder of parts as most GTR owners are. Contact to arrange postage as I am in Alice Springs, NT, but will freight stuff anywhere. All prices negotiable to some degree so make me an offer !
Precision ball bearing Gen1 6266 turbo T4 divided 0.84 a/r SP cover - requires rebuild on chra, Slightly passing oil but will smoke if used, otherwise ok. Can be rebuilt locally by Rose rage turbos or sent back to Precision - $1100
Trust T78-29D turbo, T4 divided - requires rebuild on chra. Same as above passing some oil on seals. Easy to rebuild with genuine Mitsubishi parts - $900
NPC 10" single plate push clutch rated to 450kw. NPC7056B-10 Good condition, suit all RB push setups - $700
RB26 R33 flywheel - $200
NEW Prosport 60mm dual stepper motor type JDM series 40psi electronic boost gauge with pressure sensor, harness and 60mm gauge cup. Has dual analogue needle and digital readout, programmable warning light. - $220
Used BPP 14mm twin entry fuel rail - $150
Used Nissan RB26 90A alternator - $150
Used standard R32/R33 GTR blow off valves - $150
Used Turbosmart FPR800 adjustable fuel reg in blue. Fitted with AN6 male flare inlet and 5/16" hose barb outlet fittings - $150
Used BNR32 front upper control arms - $150
Used RB26 lower front belt timing cover - $50
2 X New RB26 genuine NIssan head gasket 11044-05U16 - $90 each (rrp $130)
60mm electronic boost gauge, 1.6bar max with MAP sensor. 60mm gauge cup included. Remote peak / hold controller - $90
3 x R34 GTR lower shifter bush - $10 each.
R32 / R33 GTR pull clutch slave cylinder and hose - $90
Used Rear R33 GTR sway bar - $90 (Good S14 or S15 upgrade)
NEW R33 GTR / GTS25T STS Performance (made in UK) 3 ply silicone lower radiator hose in RED from GCG turbos (not chinese ebay crap) - $45
Used R32 GTR front diff centre - $200
USED RB26 LONG NOSE CRANK - $600
Carbon fibre N1 bootlip spoiler -$250
FRP N1 bootlip spoiler in TH1 blue - $200
SARD / DENSO 1000cc injectors. Low impedance , 0.85ms latency. Fit 10.5mm (standard) or 11mm fuel rail. - $450
Tomei RB26 sump baffle - $150
Nitto 2.8 billet 4340 steel full counter stroker crankshaft - 77.7mm. Done 600km from new. Not used since regrind to mains (10thou) -0.25mm and big ends (20thou) -0.50mm. Rebalanced, crack tested, checked for straightness and journal hardness by Rick Corbett Engineering in Adelaide 19th. November 2018 - $2900 ono (worth $5600 new + $500 machine work.) - SOLD
HKS T51S v band in / out ex housing 1.00 A/R Turbo (based on Garrett TA51 / TA45S). Comes with T4 to HKS 99.1mm V-band manifold flange adaptor (these are rare as hens' teeth) and HKS 115mm turbine v-band flange and clamps. Made 500+kw on 98ron - $1450 - SOLD
Camtech CT3536/37 445B R32 / R33 RB26 inlet / exhaust camshafts - 272 deg. 9.7mm lift. Trial fitted only. - $750 - SOLD
HKS EVC III boost controller complete with instructions. Max boost 2.0 bar - $250 - SOLD
HKS EVC IV boost controller complete with instructions. Max boost 2.5 bar  - $270 - SOLD
Used genuine R32 / R33 RB26 CAST ALLOY upper timing gear cover - $450 (These are now worth $900+ new) - SOLD
NEW genuine Nissan 31 tooth spline rear diff half shafts (Suit Quaife or OS Giken rear diff upgrade for pre 94 R32 GTR which is 30t standard) - $900 - Almost impossible to obtain now - SOLD
2nd set of NEW genuine Nissan 31 tooth spline R32 / R33 GTR rear diff half shafts (Suit Quaife or OS Giken rear diff upgrade for pre 94 R32 GTR which is 30t standard) - $900 - Almost impossible to obtain now. Will be the last set ever I obtain. - SOLD
Modified R32/R33 transfer case. 10 clutch plate (standard is 7 plate) Racepace / Midori Sebei / AGY style upgrade. Fully rebulit back to factory 0.2 - 0.5mm clutch pack clearances when clutch pack was modified (new retaining pressure plates, clutch plates, oil pump o-rings, strainer filter, ect). - $1900 ono - SOLD
2ND Modified R32/R33 RB26 GT-R transfer case. 10 clutch plate (standard is 7 plate) Racepace / Midori Sebei / AGY style upgrade. Fully rebulit back to factory 0.2 - 0.5mm clutch pack clearance. This one is at 12 thou / 0.305mm with a 5.0mm rear and 5.4mm front retainer plates - $2100 - SOLD
Tomei rb26 type B valve springs with retainers. Done about 1000km - $450 - SOLD
Nitto RB head drain with 5/8" push on fitting - brand new ! - $185 - SOLD
Used Trust NS1310G 13 row oil cooler. 300 x 185 x 50mm with -AN10 fittings  - $200 - SOLD
ARP RB26 main studs. Done about 1000km - $150 - SOLD
NEW 6 x 11mm Golebys bosch EV14 injector adapters with o-rings - $70 - SOLD
NEW R32 GTR genuine Nissan Pitwork power steering belt 4PK950. Trial fitted only as now have Ross balancer and need 4PK925 so it's too long. - $30 - SOLD
Used R33 GTR genuine rear upper control arms - bushes intact - $50 - SOLD
Used R32 GTR genuine rear upper control arms - bushes intact - $50 - SOLD
Used RB26 crankshaft lower timing belt gear - $70 (worth $170 new) - SOLD
Used Link G4 plug in GTR ECU fitted in R32 GTR ECU case - $1500 - SOLD
Used 6 X Bosch 2000cc injectors with 14mm full length adaptors - $400 - SOLD
NEW R32 / R33 SKYLINE AND GTR GEARBOX SHIFTER LOWER BOOT 74967-05U00 - $50 (rrp $70) -SOLD
NEW Skyline BCNR33 GTR and ECR33 GTS25t heater blend air mix actuator 27732-15U01 (one of the two causes of that stupid R33 aircon fan clicking sound common fault) - $220 - SOLD
USED R32 GTR ROSS TUFFBOND METAL JACKET HARMONIC BALANCER - $550 Like new. Done 1000km - SOLD
Race clutch by Jim berry full monty 4000lb 5 puck push style race clutch. Comes with push release bearing and correct 16mm bearing carrier- $1300 (Slightly used - has less than 0.5mm wear) - SOLD
2 x R32/R33 GTR splitfire coilpack sets  SF-DIS-001- $300 each - SOLD
R32 GTR interior clock - DOESN'T WORK for parts only - $50 - SOLD
TRUST / Greddy RB26 R32 / R33 GTR extended sump with pickup and baffle. Ready to bolt on - $800 - SOLD
HKS DLI twin power with R32/R33 GTR plug in harness 43001-AK001- $450 now discontinued - SOLD
Forged CP pistons 86.5mm with used rings less than 500km - $600 - SOLD
Crower I-beam billet steel conrods - $1000 used but almost like new (Cost me $2200) - SOLD
RB starter motor from R32 GTR - $150 (new ones are $700) - SOLD
Nitto 86.5mm 2.8l stroker pistons - $1000 used but almost like new (must be used with Nitto 2.8 crank as piston pin height is different to standard) - SOLD
Nitto 121.5mm billet steel I-beam conrods - $950 used but almost like new - SOLD
Nitto oil pump - $1000 used but like new -  SOLD
Apexi Power FC boost control kit - 3 pin 415-A001- $350 (suits R32/R33/R34 GTR, early S14, R33 GTS25t Skyline) - SOLD
Apexi D-Jetro Power FC with new type EL type hand controller 414BN035  - $1250 includes 2 x APEXi (Denso) 3 bar MAP Sensors (499-X001) 1 x MAP Sensor Harness (415-XA04) - SOLD
R32 GTR R200 30 tooth spline rear diff half shaft pair - $400 (used in Nismo GT diffs) - SOLD
BARELY USED R33/R34 GTR RB26 genuine long nose crank fully balanced - $1200 used but almost like new. Has had $500 of machine balancing for high RPM - REPORT AVAILABLE (Just crank new is $1900 rrp) - $1250 - SOLD
R33 GTR converted to push type gearbox rebuilt with replaced synchros - $1450 Not used since rebuild. Still in shed not fitted. Fitted with R32 transfer case. - SOLD
4 x R32 GTR 16 x 8 wheels with 255/50 Mickey Thompson ET street drag radials. - $900 - SOLD
R32 GTR mechanical LSD rear diff centre. Suit 30 tooth spline - $195 - SOLD
R32 GTR rear diff cover (89 - 92 early type - finned) - $120 - SOLD
Used HKS purple alloy oil filler cap - $30 - SOLD
NEW ARP RB26 flywheel bolts - $75 -SOLD
Used R32 GTR / GTSt adjustable rear upper control arms - $60 - SOLD
NEW genuine NISMO 1.3 bar radiator cap - $50 - SOLD
Used Nismo 65deg C low temp thermostat - $40 suits all RBs - SOLD
NEW TOMEI 1.5MM BLOCK RESTRICTOR - $10 - SOLD
R33 GTR standard ECU - $150 - SOLD
NEW NISSAN 14mm PUSH CLUTCH RELEASE BEARING SLEEVE / CARRIER 30501-N1604 (rrp $50) used on a lot of multi plate clutches. CARRIER ONLY (suits most multi plate clutches out there eg. Exedy Hyper Twin ) - $40 - SOLD
Used 18mm push clutch release bearing carrier and release bearing 30501-S0260 / 30501-S0200 (used on standard R32 GTR, OS GIKEN R4C, TS3B clutch and other multi plate clutches) - $50 - SOLD
Used 26mm push clutch release bearing carrier and release bearing 30501-K0510 (used on OS GIKEN R3C  and R3B clutch and other multi plate clutches) - $50 - SOLD
OS Giken OS-88 direct shifter with gearknob - (shifter only, no retaining rings) - $100 -SOLD
Trust / Quaife 3F1 6 speed H pattern straight cut dog box with freshly modified 10-plate transfer case. $8300 ono - SOLD
OS GIKEN 5 speed transmission. Uprated 24t OS input shaft. New Updated R33 GTR series 3 synchros and selector forks. Push type clutch release. R32/R33 GT-R transfer case. Business only addresses only- $6000 - SOLD
Will list more as I get the time. Contact Ben on 0401 779 905
OS GIKEN 5 SPEED TRANSMISSION WITH R32 GTR TRANSFER CASE
R32 GTR REAR MECHANICAL LSD DIFF CENTRE - 30 TOOTH SPLINE
R32 / R33 GTR FRONT OPEN DIFF CENTRE
RB26 86.5MM CP FORGED ALUMINIUM PISTON SET
RB26 CROWER BILLET STEEL I BEAM CONRODS WITH CROWER ROD BOLTS
NITTO / JE FORGED ALUMINIUM 2.8L 86.5MM PISTON KIT
RB26 LOWER TIMING BELT COVER
NITTO RB26 BILLET STEEL I BEAM CONRODS WITH ARP 2000 ROD BOLTS
RB26 GTR LONG NOSE FULLY BALANCED CRANKSHAFT
R33 GTR 5 SPEED TRANSMISSION - FULLY RECONDITIONED
R32 GTR REAR UPPER CONTROL ARMS - GENUINE STANDARD
R33 GTR AND GTS25T HEATER MIXER - BRAND NEW. FIX THAT STUPID CLICKING SOUND IN YOUR R33.
R33 GTR REAR UPPER CONTROL ARMS - GENUINE STANDARD NISSAN
NEW NISSAN 14MM PUSH CLUTCH RELEASE BEARING SLEEVE
NITTO 77.7MM 2.8 BILLET FULL COUNTER STROKER CRANK - FRESH FROM MACHINE SHOP
OS Giken OS-88 solid direct shifter
Ross tuffbond metal jacket harmonic balancer / damper
Jim berry race clutch
No clutch with box as I'm still using my ATS carbon triple. Had around 530kw at wheels through it. About 1500km old. Only throwing it out there for offers as if it does not sell it goes back in my 32. Just thinking about going back to a dog box and won't need giken if I go that way.
i'll be around that power level once engine build has finished, ill do more research and come back to you
Ok there is a heap of interest in the OS giken 5 speed gearbox, I actually have 2 of these. Lets be clear - offers over $5500 . No 4k as this doesn't even cover gearset / input shaft.
To get one of these going it is at least $6k in parts, as the gearset + input shaft cost is around $5k. Genuine Nissan selector forks / synchro rings / bearings and other unforseen parts depending on what you have to replace when it's down is $1k - $2k range. Then you need a good existing box for it to go in, not to mention labour costs on top of that if you are getting someone to do it for you. I am not in a hurry to sell one of these Giken boxes, but would let one go for the right price. If not go and build one yourself and find out the cost to get one running.
Also have a stock R33 GTR box rebuilt and unused since rebuild. - SOLD
WP_20181004_14_52_40_Pro.thumb.jpg.22832edb7e7c286d2e97bf66dfb752aa.jpgWP_20181004_14_52_29_Pro.thumb.jpg.d913f50e706261c0e89d28d3f8da0fa4.jpgWP_20181004_14_52_19_Pro.thumb.jpg.d895a467feb4143b57f486ec12ef2426.jpgWP_20181004_14_52_15_Pro.thumb.jpg.3e050dba25e4492367e8784aa81a0916.jpg
Price drop - $1450 - SOLD
Fully reconditioned and not used since. Can be supplied as push or pull setup. (currently push)
RB26 Nitto oil pump - SOLD
R32 starter motor - SOLD
R32 GTR wheels - SOLD.
First post will be constantly updated for parts availability - all price dropped !
Make an offer. Everything is negotiable and can ship anywhere.
New photos of rebuilt and reconditioned R33 GTR transmission. Now fitted with R32 GTR transfer case. Setup as push box.
WP_20181010_17_03_35_Pro.thumb.jpg.598dc848a58e90b4a1385353d8e76d2f.jpgWP_20181010_17_03_45_Pro.thumb.jpg.347ce3ed8e2cfd87d4d36c39c30e1951.jpgWP_20181010_17_03_22_Pro.thumb.jpg.877905362c55ca91b4f5224094a8ed64.jpg
30 tooth R32 GTR rear diff half shafts, Nitto billet rods and CP pistons SOLD pending payment.
Newly added to first post.
R32 / R33 GTR 8 litre TRUST Greddy extended sump. Has extended pickup and baffle. Complete bolt on. $800
Trust sump pics. Has fitting for head drain also. Freight is about $70 - $90 depending on location. Straight out of my R32.
Going dry sump, so now not needed. Would put it on my R33 GTR if I could be bothered to pull engine out.
WP_20181017_11_21_33_Pro.thumb.jpg.de7ecbaf2451ad122e3e2b33111afffb.jpgWP_20181017_11_21_26_Pro.thumb.jpg.311908f331c8c0bfdeacbef6fc40fa70.jpgWP_20181017_11_21_18_Pro.thumb.jpg.7c96e2340c27f720efd00a42512cde72.jpgWP_20181016_16_42_30_Pro.thumb.jpg.486446135fb4f719427940c55e3916fb.jpgWP_20181016_16_42_16_Pro.thumb.jpg.690b8ba2cc064a82b662bba0caac0a5e.jpgWP_20181016_16_42_03_Pro.thumb.jpg.a77678cd82904e549fecabfb83be4c49.jpg
Trust RB26 sump - SOLD
CP 86.5mm pistons - SOLD
R32 GTR rear diff cover SOLD pending payment
It's all going FAST !
With the 31 spline half shafts, what else is needed to fit them to a pre 94 R32 GTR diff? I have a quaife centre that i eventually want to fit into my car.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
