Hi,
For sale is my much loved r32 gtr . This was my dream car and i shopped around for a while to find the right car. Reason for selling is i am looking at getting into track racing more and the skyline is to much of a nice car to put around the track.
Good Points.
short motor
acl forged pistons
eagle h rods
acl race bearings
r34 n1 crank
n1 oil pump
tomei oil restector
r34 n1 main bolts
step 2 head tomei 260 cams
tomei type b valve spring kit
tomei hi lift buckets
tomei cam gears
tomei 1.2mm head gasket
arp 2000 head studs
hks gtss turbo kit
surge tank with twin bosch 044 pumps
fuel lab regulator
hypertune duel entry fuel rail
bosch 2000cc injectors
flex fuel sendor runs both e85 and 98 petrol
link g4 ecu
front brake upgrade r33 gtr brembos front and rear
strut brace
bc gold series coilovers
genuine volk t37 18x10.5 offset 22 i think.
genuine nardi deep corn steering wheel
apexi fuel pressure, oil pressure and boost gauge
awd to rwd switch in car.
car is making 330 awkw on e85 .
Had a close door respray factory colour 4 years ago.
Bad Points
Speaker blown so stero doesnt work
both front rims have small scratch from when car was on trailer
Front lower bumper has popped a clip (currently help up with cable tie)
Dash has bubble
no horn
$37000
Located Wagga Wagga NSW 2650
No Swaps
Email : [email protected]
Plates do not come with car.
  • Like 1
https://www.sau.com.au/forums/topic/475067-gtr-r32-for-sale/
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
