pic1 pic2 pic3
Howdy, About 2 months ago i bought my first skyline from some guy who did alot of backyard modifications to it. I bit off way more then i can chew but i have been trying to get into cars/find myself a new hobby.
Basically after i bought it i was transferring interstate to VIC and getting a rwc was a nightmare. Turbo to big, cammed, disgustingly loud , to many mods etc etc. Finally 2.8k later I got it Plugged up to quieten it down, had all its lights and such fixed,blinkers etc etc fixed.
Now its in a RnR mode, Cant idle correctly, and basically needs a ECU and a tune because as far as i can see, it has an old LINK chip and a tuning cable (which plugs into a a hand controller with a serial connection,which didnt come with the car). So now im in country victory, with no tuners nearby, with a car that can barely run, and hopefully in next few months, ill save a bit more for a haltech ecu + a tune.
Ive been just doing little projects on it now since ive finally got the car in my name from the road worthy. Such as swapping steering wheels, fixing the seats, trying to find cutouts and matts because boot didn't really come with a liner. If anyone has any info on nearby tuners such as ballarat or geelong (im located in warrnambool), rather then going all the way to melbourne that would be great =D.
(no access to trailers etc) Any cheaper alternatives for an ecu im happy to hear. Hopefully over next few months ill get her running sweet and be good for cruises.
Been hovering these forums for months just trying to learn anything i can since ive basically spent my whole life on computers. And i hope this forum and car can help me gain some new experiences, friends , and knowledge.
cheers
Theoretically you should be able to plug the Link into a laptop with the appropriate software (although you may have trouble with modern laptops not having the right connection).
Another possibility is to refit the OEM ECU with a Nistune chip installed. If you know the turbo specs, injector size etc someone could probably pre-install a good enough tune to keep you going until you can get to a tuner.
PS car in pics looks very clean and straight!
Would need the hand controller for that link tuning plug. Because the hand controller has the serial port on it. G1 link or something going by what I found but they haven't been made in years. Also I thought nistunes are not done on rb25det ECUs and would need to source a RB20 one. Here's some more pics since in im currently in the shed poking around In it . Also paints really bad up close haha. Pic for reference . It use to be green
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
