The project is now sold and I have 8.5 years worth of parts to clear.
Most parts come from an R34 GTT automatic sedan 1998. May suit other similar vehicles.
All parts located in Melbourne in Pascoe Vale South VIC (near Essendon).
Unless otherwise indicated all parts are used and were working when removed, however have been sitting for several years now. Please inspect carefully on pickup. Caveat emptor.
Here's the deal:
- Selling in LOTS ONLY (see below)
- PICK UP ONLY
- Cash on pickup
- Whatever hasn't cleared by the end of the month will go to the wreckers
Please see PHOTOS of parts here: https://bit.ly/R34parts . Sorry they are not super organised, there's parts everywhere...
INTERESTED? Please PM me.
BONUS: I'll be happy to sell everything except the semi slicks (= lots 2-16) for $1k if someone wants to start a Skyline parts service... :)
qVm9MSufMFFW8qphfduz9P15gVTUBK-k7RyqC7iz
^^^ Click to view album!
LOT 1 - GREAT SEMI SLICKS TOYO R888R
Toyo Proxes R888R 225/45ZR17 (91W UTQG 100) x4
Mounted on R34 GTT stock wheels 17X7.5", painted in satin black
- These are an amazing track tyre, very predictable on the limit and great heat characteristics.
- Lots of meat left: Tread depth 3.96-4.06mm (vs. 5mm new). They've seen about 4-5 track days
- Date of manufacture: Week 18/2015
- Tyres bought new late 2015, cost $1,600 inc. wheels
ASKING $990
DLpHPPuEW4_vFoHKTuXG-qkxxtUVbEhS17pOzjj5
LOT 2 - OP6 TURBO
R34 GTT stock OP6 turbo unmodified
- Was running around 200rwkw when removed
- Removed working at ~127,000kms in late 2013
- Great for R34 GT, other Nissan engines or highflow
ASKING $250
LOT 3 - RACING HARNESS
Sparco Cinturo 4-point racing harness
- Manufactured April 2014
- Seen about 10 track days
ASKING $100
LOT 4 - RB25DET NEO HEAD STUDS ARP+STOCK
- ARP 202-4301 head studs, bought and installed in late 2016, used for about 3 months (new price $327.80 at Kudos)
- Set of OEM head studs
ASKING $150
LOT 5 - NEW SERVICE PARTS
- $71 Castrol Edge 10W-60 full synthetic 5L
- $38 Nulon premium long life coolant pre-mix 6L
- $9  Castrol power steering fluid
- $15 Ryco A360 air filter
= $133 NEW at Supercheap. All except the air filter bought in 2018.
ASKING $100
LOT 6 - R34 GTT STOCK EXHAUST PARTS
- Exhaust system (dump, dump heat shield, midpipe, cat, muffler - no bolts)
- O2 sensor (unknown condition)
- Turbo heat shield
Good for clearing defects perhaps.
ASKING $100
LOT 7 - R34 GTT STOCK SUSPENSION PARTS
- Swaybars front and rear (good upgrade for a GT)
- Swaybar links and bushes (unknown condition)
- Rear HICAS rack and arms x2
- Steering rack universal joint
- Steering rack (leaking; needs new seal at steering column)
- Suspension top hats x4
- Suspension top hat covers x2
- Suspension arms (most, some with Whiteline eccentric camber bushes)
ASKING $150
LOT 8 - R34 GTT STOCK BRAKE PARTS
- Brake lines x4
- Brake pedal auto
- Front brake discs x2 (unknown meat left)
- Rear brake discs x2 (unknown meat left)
- Brake pad shims x4 and clips
- R34 GTT brake booster with BM50 master cylinder
- R34 GT brake booster with BM44 master cylinder
- Boot centre brake light
ASKING $150
More info about the brake boosters here: https://www.sau.com.au/forums/topic/468550-fs-r34-gtt-gt-brake-boosters-bm50-bm44-bmc-dba-t3-310mm-rotors-an10-hoses-r34r33-transmission-parts-mel/
LOT 9 - R34 GTT STOCK++ FUEL SYSTEM PARTS
- Fuel regulator
- Fuel pump
- Walbro 255 fuel pump
ASKING $100
LOT 10 - R34 GTT STOCK IGNITION PARTS
- Coil pack cover
- Coil pack harness
- Coil packs x 20 maybe? (various conditions)
ASKING $100
LOT 11 - R34 GTT STOCK ENGINE++ PARTS
- Sidemount intercooler brackets x2
- PS steering cooling loop
- Auto trans flex plate
- Water pump and pulleys (removed at 150k service)
- Engine mounts x2
- Gearbox mount x1
- Oil pressure sensor (unknown condition)
- Oil heat exchanger (from near filter housing, unknown condition)
- Fly wheel bolts x6
- Intake pipe
- Engine cover
- Engine cover bracket
- Various heater hoses
ASKING $100
LOT 12 - R34 GTT STOCK RADIATOR
- Radiator
- Radiator cap
- Radiator cap, Trident
ASKING $100
LOT 13 - R34 GTT STOCK DRIVELINE PARTS
- Tail shaft front part (auto)
- Diff centre VLSD (from auto)
- Diff stub axles
- Diff bushes x2
The VLSD is perhaps an upgrade for a non-LSD R200...?
ASKING $100
LOT 14 - R34 GTT STOCK OTHER PARTS
- Navigation unit lid (some scratches)
- Xanavi navigation unit (won't work in Australia)
- Xanavi navigation unit screen (uknown condition)
- Rear vision mirror (cracked)
- Coin tray (near steering column)
- Lock nuts x4
- Wheel guard plastic lines (PROTECTOR-FR FE, 63843-15U00, new never used)
- Front passenger door lock actuator (second hand, untested)
ASKING $100
LOT 15 - ENGINE SWAP LEFTOVER PARTS
These came mostly from the replacement RB25DET Neo with ~129k on it, which was in running condition with good compression.
- Cam gear
- Flex plate
- Oil filter housing (broken)
- Engine mount/s
- Cam belt
- Oil filter housing heat exchanger (unknown condition)
- Pipes and hoses, random
- Intake manifold top half (with some heater hoses)
- Intake manifold bottom half (with some heater hoses)
- Cam covers
Plus parts from my original, which blew at bottom end at ~156k
- Clutch fan (unknown condition, some cracks in plastic around the base)
- Intake cam (from original engine)
- Exhaust cam (from original engine)
- Exhaust manifold (from original engine, slightly heat deformed)
- Exhaust manifold heat shield
ASKING $150
LOT 16 - MISCELLANEOUS PARTS
- Wheel nuts set (may not be Skyline?)
- K&N air filter (needs a good clean)
- BC Racing BR rear springs 5kg/mm x2
- Defi exhaust temp sensor (busted but good for cable & connector)
- Defi exhaust temp sensor cable (new never used)
- Aluminium catch can (very little use)
- Saas hose clamp 64mm
- Tridon radiator cap
- AFMs x2 (orange label, pink label - unknown condition)
- Intercooler rubber joiners x2
- Ignition noid light (new never used)
- R33 GTS tail shaft rear part (coupe manual)
- Oil sandwich plate for sensor/s (needs new rubber seal)
- Oil and fuel hose lengths, miscellaneous
ASKING $150
Thanks for looking!
I may actually be interested in the harness if no one else is, the one I have has to be entirely unwound to fit through the slots in my current seats, which is a slight bit annoying as I don't see myself changing my seats to fit the harness I currently have.
  • Like 1
First dibs, all yours if you want it! Nothing like running a harness on the street, perfect for those supermarket trips :)
Howdy matey
im interested in Lot 14 for the Xanavi navigation unit screen as my screen is in bad shape, like the lcd has melted. Please let me know where we can meet - i need your advice on taking the system apart to swap out.
thanks
Mike
  • Like 1
20 minutes ago, MikeyM said:
Howdy matey
thanks
Mike
Cheers mate, PM sent
Found more stuff last night:
Adding to LOT 16 - MISCELLANEOUS PARTS
- 2x jumper cables
Same asking price for the lot as before.
New LOT 17 - GPS RECEIVER
- Dual SkyPro GPS Receiver for iOS/Android (Black/Red, XGPS 160)
- Makes position recording more accurate and works with Harry's LapTimer
- Paid $200 new, used for 4-5 track days maybe
'Ideal for pilots, race car drivers and boating, this 2nd generation GPS  Receiver features even faster signal acquisition, 10Hz positioning  updates and Bluetooth connectivity to up to 5 devices. The WAAS receiver simultaneously receives both GPS (USA) and GLONASS (Russia) satellite system signals.'
Asking $100
See photos at https://bit.ly/R34parts . I've also added a couple of shots of the ARP and OEM head studs.
Also LOT 3 - RACING HARNESS is now sold, to Greg :)
Xanavi parts are now sold:
- Xanavi navigation unit screen (unknown condition)
- Lock nuts x4
ASKING $20
ARP head studs are now sold:
ASKING $20
Here's a summary list, all prices ONO:
LOT 01 - $990 - GREAT SEMI SLICKS TOYO R888R
LOT 02 - $250 - OP6 TURBO
LOT 03 - SOLD - RACING HARNESS
LOT 04 -   $20 - RB25DET NEO HEAD STUDS STOCK
LOT 05 - $100 - NEW SERVICE PARTS
LOT 06 - $100 - R34 GTT STOCK EXHAUST PARTS
LOT 07 - $150 - R34 GTT STOCK SUSPENSION PARTS
LOT 08 - $150 - R34 GTT STOCK BRAKE PARTS
LOT 09 - $100 - R34 GTT STOCK++ FUEL SYSTEM PARTS
LOT 10 - $100 - R34 GTT STOCK IGNITION PARTS
LOT 11 - $100 - R34 GTT STOCK ENGINE++ PARTS
LOT 12 - $100 - R34 GTT STOCK RADIATOR
LOT 13 - $100 - R34 GTT STOCK DRIVELINE PARTS
LOT 14 -   $20 - R34 GTT STOCK OTHER PARTS
LOT 15 - $150 - ENGINE SWAP LEFTOVER PARTS
LOT 16 - $150 - MISCELLANEOUS PARTS
LOT 17 - $100 - GPS RECEIVER
Would you split the Catback section of the stock exhaust? I'm in reasonably desperate need of any exhaust as mines kaput from the catback... :(
Hey mate, I'd rather sell together but I'll shoot you a PM and see what we can do
Revised prices, ONO:
LOT 01 - $890 - GREAT SEMI SLICKS TOYO R888R 225/45ZR17
LOT 02 - $200 - OP6 TURBO
LOT 05 -   $80 - NEW SERVICE PARTS
LOT 06 -   $80 - R34 GTT STOCK EXHAUST PARTS
LOT 07 - $100 - R34 GTT STOCK SUSPENSION PARTS
LOT 08 - $100 - R34 GTT STOCK BRAKE PARTS
LOT 09 -   $80 - R34 GTT STOCK++ FUEL SYSTEM PARTS
LOT 10 -   $80 - R34 GTT STOCK IGNITION PARTS
LOT 11 -   $80 - R34 GTT STOCK ENGINE++ PARTS
LOT 12 -   $80 - R34 GTT STOCK RADIATOR
LOT 13 -   $80 - R34 GTT STOCK DRIVELINE PARTS
LOT 15 - $100 - ENGINE SWAP LEFTOVER PARTS
LOT 16 - $100 - MISCELLANEOUS PARTS
Happy Friday!
Well that escalated quickly:
LOT 02 - SOLD - OP6 TURBO
LOT 06 - SOLD - R34 GTT STOCK EXHAUST PARTS
- Coil pack cover
- Coil pack harness
Asking $50
In LOT 11 - R34 GTT STOCK ENGINE++ PARTS:
- Engine cover
Asking $50 for the rest of Lot 11
Cams sold:
Asking $100 for the rest of Lot 15
^ Pic of wheels and semis on the car, see Lot 1 below
Here's what's left at the moment, all prices negotiable:
LOT 1
- Wheels are stock Nissan Skyline R34 GTT: 225/45R17 7.5Jx17 ET40 PCD 5x114.3
- This is a square set and regularly rotated for very even tyre wear
- May suit R32, R33, Z33, S14, S15 and other vehicles, especially with spacers
ASKING $850
LOT 2 - SOLD
LOT 3 - SOLD
LOT 4
ASKING $20
- Castrol Edge 10W-60 full synth 5L
- Nulon coolant pre-mix 6L
- Castrol PS fluid
- Ryco A360 air filter
ASKING $100
LOT 6 - EXHAUST PARTS
- O2 sensor (unknown cond)
ASKING $10
LOT 7 - SUSPENSION PARTS
- Swaybars F & R
- Swaybar links & bushes (unknown cond)
- Rear HICAS rack & arms x2
- Susp. top hats x4
- Susp. top hat covers x2
- Susp. arms (most)
ASKING $100
LOT 8 - BRAKE PARTS
- Brake lines x4
- Brake pedal auto
- Front brake discs x2, rear brake discs x2 (thickness?)
- Brake pad shims x4 & clips
- R34 GTT brake booster w/ BM50 BMC
- R34 GT brake booster w/ BM44 BMC
ASKING $100
LOT 9 - FUEL SYSTEM PARTS
- Fuel reg
- OEM fuel pump
ASKING $80
LOT 10 - IGN PARTS
- Coil pack harness
ASKING $50
LOT 11 - ENG PARTS
- Water pump & pulleys (removed at 150k service)
- Engine mounts x2
- Gearbox mount x1
- Oil pressure sensor (unknown cond)
- Oil heat exchanger (from near filter housing, unknown cond)
- Intake pipe
ASKING $50
LOT 12 - RADIATOR
- OEM radiator
- Rad cap
- Rad cap, Trident
ASKING $80
LOT 13 - DRIVELINE PARTS
- Diff stub axles
- Diff bushes x2
ASKING $80
LOT 14 - OTHER PARTS
- Lock nuts x4
- Wheel guard plastic lines (new never used)
- Front passenger door lock actuator (s/h, untested)
ASKING $20
LOT 15 - ENGINE SWAP LEFTOVERS
From the replacement RB25DET Neo:
- Cam gear
- Flex plate
- Engine mount/s
- Cam belt
- Oil pres. sensor (unknown cond)
- Oil filter housing heat exchanger (unknown cond)
- Pipes & hoses, random
- Intake manifold top & bottom halves (with some heater hoses)
- Cam covers
From the original Neo:
- Clutch fan (unknown cond, some cracks in plastic around the base)
- Exh. manifold (slightly heat deformed)
- Exh. manifold heat shield
ASKING $100
LOT 16 - MISC PARTS
- Wheel nuts set (unknown)
- K&N air filter
- Defi exh. temp sensor (busted but good for cable & connector)
- Defi exh. temp sensor cable (new never used)
- AFMs x2 (orange label, pink label - unknown cond)
- Oil & fuel hose lengths, misc.
- 2x jumper cables
ASKING $100
Asking $100
Lots 4, 11, 15 sold. Here's what's left, all prices ONO:
$750 – LOT 1  – SEMI SLICKS: Toyo Proxes R888R on R34 GTT wheels
SOLD – LOT 2  - OP6 TURBO
SOLD – LOT 3  - RACING HARNESS
SOLD – LOT 4  – RB25DET NEO HEAD STUDS ARP+STOCK
$100 – LOT 5  - NEW SERVICE PARTS
$10  – LOT 6  - EXHAUST PARTS: O2 sensor
$100 – LOT 7  - SUSPENSION PARTS
$100 – LOT 8  - BRAKE PARTS
$80  – LOT 9  - FUEL SYSTEM PARTS
$50  – LOT 10 - IGNITION PARTS: Coil pack harness
SOLD – LOT 11 - ENGINE PARTS
$80  – LOT 12 - RADIATOR
$80  – LOT 13 - DRIVELINE PARTS
$20  – LOT 14 - OTHER PARTS
SOLD – LOT 15 - ENGINE SWAP LEFTOVERS
$100 – LOT 16 - MISC PARTS
$100 - LOT 17 - GPS RECEIVER
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
