Hey guys just wondering if anybody has had a low fuel pressure problem? My v35 was sitting for a couple of months waiting for a new clutch after it was all installed i cranked it over and it started fine but instantly started idling rough revd do op to 500 and almost stalls, there is little to no throttle response and will stall if you dont pump the accelerater to try get the revs up? Has anyone had any similar issues?
https://www.sau.com.au/forums/topic/475533-v35-issue/
When it first ran bad it threw two codes for the vvt solenoids we cleared it and it came back straight away i bought new ones and codes are gone speaking with a couple of my mates they sugested a couple of things that it could be a mechanic friend said it sounded like a blocked exhaust but we unbolted it and didnt change anything also low oil pressure was suggested we checked it last week and pressure seemed normal except it would rise and drop with the revs when it was about to die. Then it was brought up that it might be starving for fuel and without trying to rig up the oil pressure guage to the fuel line i cant tell if it is, so i was turning to the forum i get most of my answers from for advise ??
and i havent cleaned out throttle body yet
https://www.sau.com.au/forums/topic/475533-v35-issue/#findComment-7892846
Well im just seeing if anyone has some advise for anything i can check to cross off the list, trying to avoid the mechanics but if its too hard to pinpoint ill take it in. Ive looked through alot of threads and havent seen anything with the same symptoms as mine. I know it might be annoying to tell people the same shit but if anyone has anything i can try i would appreciate the advice ?
https://www.sau.com.au/forums/topic/475533-v35-issue/#findComment-7892922
The usual list is:
  • Dirty fuel injector(s)
  • Fouled/worn spark plugs
  • Faulty coils
  • Dirty IACV
  • Dirty/stuffed AFM (including dirty sensor element, dry/cracked solder joints, bad loom pin connections)
  • Bad CAS loom pin connections
  • Dying fuel pump or FPCM
And to that there is a random selection of other possible shit, like the O2 sensor can cause wierdnesses, the fuel pressure reg could just possibly be stuck open, and so on.
https://www.sau.com.au/forums/topic/475533-v35-issue/#findComment-7892941
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
