Hey all,
Due to some recent upgrades and to sell a couple of unused items, I have the following gear for sale. All items are in working order (except where noted) and were removed from a 1990 R32 GT-R making just over 300KW. But....in some cases they are 28ish years old so "caveat emptor". Please consider this if you are interested.
Collection in Melbourne.
GT-R Stuff
1. SOLD R32 GT-R OEM Intercooler
Price: $50.00
Reason for sale: upgraded to a new Plazmaman cooler
2. SOLD Apexi Power FC (no hand controller)
Price: $200.00
Reason for sale: replaced with Nistuned OEM ECU
3. SOLD R32 GT-R Twin Turbo Pipe
Price: $30.00
Reason for sale: replaced with a wrinkle black painted pipe
4. SOLD R32 GT-R OEM Coilpack, igniter etc.
Price: $50.00
Reason for sale: upgraded to Alpha Omega Racing ACDelco Coil setup
5. GONE R32 GT-R Gearbox - SUIT A REBUILD
Price: $270.00
Reason for sale: replaced with a brand new R33 S3 gearbag
Note 1: I don't have any pictures of this as it is in storage.
Note 2: Early model push type box
Note 3: I believe that the gearset is OK but synchros are knackered
Note 4: It was very difficult to engage 1st gear but the clutch was also on death's door
Note 5: Did I mention that it it needs a rebuild?
Note 6: Comes with free oil
6. SOLD 6 x RC Racing Injectors
Price: $25.00
Reason for sale: replaced with new injectors to support E85
Note 1: I don't believe these are very good so "caveat emptor" as per above.
Note 2: I think they are 850cc
Other stuff
7. 2 x Philips Xenon D1S X-tremeVision gen2 (BNIB)
Price: $100.00
Reason for sale: I was going to use these in another car but went a different route. They are brand new and have not been removed from packaging. I think that I paid about $350.00 for these.
8. SOLD Pioneer TSWX305B Bass Reflex Subwoofer (BNIB)
Price: $45.00
Reason for sale: TBH, I don't know why I bought this. Possibly drunk. It would never have fit in anything that I owned at the time. Stock pic below
I am open to reasonable offers and will ship via E-Go. If anything is way over priced, then please don't sledge like you are David Warner (when he was allowed on the pitch); just let me know or - if you are interested - send me a link to a realistic price.
There is also a bag with some additional screws / bolts / etc. so if something appears to be missing, let me know.
Cheers
Rob
Edited by Robzilla32
Updated to show Intercooler sold
https://www.sau.com.au/forums/topic/475733-fs-r32-gt-r-parts-and-other-stuff/
  • Robzilla32 changed the title to FS: R32 GT-R parts and other stuff
  • 1 month later...
Subwoofer sold. Thanks @shodan !
For those awaiting pics of the gearbox, my apologies but it is in storage and I still don't have access to it. I will update you via PM / TXT when I can. I completely understand if you have lost interest though.
Intercooler, Twin Turbo pipe and Xenons still available. Send me an offer. I thought the intercooler may have been of interest or do most people just go straight to aftermarket these days?
Cheers
Rob
  • 1 month later...
  • 1 month later...
  • 3 months later...
  • 2 months later...
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
