Hi.
First of all, do anybody in here know if there are different deck height on the RB30 Blocks, like different models ?
Reason im asking is that I have a block here that has a 226,5mm deck height, and what other people tell me is that stock is 230.5mm
im looking for a new block, since this block keep messing things up and going out of straight.
So any info is appreciated, and let me know if someone has anything available.
Kenneth
https://www.sau.com.au/forums/topic/476061-rb30-block-needed-asap/
No, they are all the same. If you have a crazy deck height, your block has been molested by a previous owner trying to fit 25 pistons to it.
Really, you think someone has machined 4mm off the Deck, thats crazy. I been wondering since day 1 why it was so short.
Anyway, yes im in Denmark and you might be right shipping gonna be alot :(
Yes I really think the deck has been machined down that far, its lucky they didn't strike water jacket. This would certainly reduce block rigidity. You probably only have a couple of mm of solid deck surface. Sorry brother.
That might be the reason also why the mains keep getting out of straight.
Its been line bored at least 2 times. Last time it cost a 94mm spool crank after only 10 miles. Just had it in the cnc machine again and its gone in the mains again.
Absolutely. When I built my 30/25 I had the mains checked for line boring and my guy said not worth it the block was straight. The crank was also only linished and also checked out straight, the bores still showed the original hone marks top to bottom. The engine had travelled 150,000 km, and from talking to other builders this is not uncommon with these blocks. they were obviously very well cast and machined using excellent materials.
If you are running a 94mm crank throw what is the piston compression height and rod length. Asked a couple of mates and consensus was you can't remove 4mm from deck without hitting a cylinder parting. Apart from the proximity of the water gallery running just below the deck on exhaust side.
I had custum piston made to fit the spool crank and rods, so i didnt notice from the beginning that the block was actually 4mm to short. I did wonder why Jeremy at JE piston told me that stock Deck height was 230.5mm. I was sure that there had to be different kind of blocks, since i could not imagine anyone that stupid to remove 4mm from a Block.
Anyway, i need a new one and i will need to order new pistons to fit the new block, and this time hope that it will stay straight.
In case Griffin dont want to sell the one he has, do you know where to look up those kinda blocks ?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
