A few on SAU know I bought this GTR32 in late 2004 and it's hardly been on the road due to a fair few events I would have rather done without.
Last weekend I pretty much finished and driving her was a real pleasure. Only a few more very minor things I want to do.
My GTR feels very strong and I'm excited and proud. So I'd like to share a picture or two I took off my phone on the weekend.
Oh and a shameless plug for the Paint shop - Rate highly :thumbsup:
Thanks Kat - yeah I was very excited the day it cranked over. It was good to share the experience. I Looked like this all that weekend :D
Ta Andrew - No dyno yet.
Running the build in. 1000kms down and 2000kms to go. Trip to Shep should get it up there and then back to Jim at CRD for the Performance tune.
She's limited down to about a 3rd of RPM/Boost :(
Expecting 300 - 340 awks on the -7's
I'd put my hand up but I'm not really that good, but on the other hand I probably wouldn't say no if you offered it, that's after getting out of a car that has 160rwkw and getting into a car that's expecting 300 - 340 awks lol
Hi everybody,
I've had my 32 GT-R which I bought stock for a couple of years now. Decided to do a few mods recently.
I now run
ENGINE:
HKS 2.8L stroker kit
APR Main And head studs
Nitto Metal Head Gasket
2xGarrett GT2860R-5
Nismo Plenum
Tomei Expreem Manifold (Ceramic heat coated)
GReddy 264°/9.10mm Cams
N1 oil pump
Trust R-SPL Intercooler + Piping
Apexi Super Suction Kit
Z32 AMFs
GReddy Y piece inlet Pipe
Blitz BOV
Power Enterprise 700cc Injectors
Tomei Fuel pressure regulator
Nismo Fuel pump
Tomei Fuel rail
XForce 3.5 in Turbo back exhaust + Varex cannon.
Jim Berry Race Clutch.
Haltech Platinum Pro
Tein Super street coilovers
Cosmetic:
Carbon Fiber Bonnet
Nismo Floor mats
Recaro seats. (Not installed yet)
Veilside Body Kit. - Ugly as sin in my opinion.
Built and Tuned By Gas Motorsport.
Currently only running low boost. 275kw at all four on 16psi.
Pics to follow. Car is way too dirty atm to take photos.
Finally got around to ditching my ugly body kit and got a respray. I also got new wheels and got the high boost tuned.
I now have N1 front bar, stock sideskirts, and BBS LM's. (Knock offs). Colour is House of Kolor Matte Black.
Low boost is 18 PSI. I make 320kw @all4 on Pump fuel. High boost is 32 Psi and I make 380kw @all4 on VP MS- 109.
Edited by Jamtime
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
