25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
ok trying to set this up for the 28th but am having a prob's with Darlington Park, I have sent them emails asking for info & left phone messages with them & still have not gotten back to me starting to piss me off :( so will try & get time tomorrow to give them a call & get it sorted :(
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-978188
Yeah I bought them along to the skidpan day I went to and they had a blast sittin in the back, but they are a bit young to drive karts, 5yrs and 3 yrs :) But dont change dates on account of me, there will always be next time ;)
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-979181
Ok people It is set
Place --> Darlington Park
Date --> 04/09/04
Time --> 3:30pm
Cost --> $65
Maps are up it is exit 38 off the M1 coming down off the ramp go around under the highway & take Stanmore Rd & then travel down Stanmore Rd take Peachy Rd (left Turn) & is a little way along Peachy Rd :)
It is set so come one come all
Cheers Mike
List To Date 17/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados +1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Charly
Chaos
Jaqule (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Slamm
Lazy-Bastard (Y 4 D PARK)
Ska (Y 4 D PARK)
Maybe
Growtalski
Evo83 + 5
33 Niz
Nizmo-Boy
https://www.sau.com.au/forums/topic/47630-go-karting/page/3/#findComment-982520
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
