Why the f**k can't I bleed this f**ked up cooling system. I'm about to drive this flamin mongrel into a pole.
I have tried every single way possible for over a week and still it overheats or spews all the coolant out of the radiator funnel. I've searched on here and tried all the tricks you guys have used, all the tricks the 350z guys use, the old fashioned way and nothing works.
I'm running the coolant bypass mod and have a tap on that with a funnel filled with coolant and it just continues to blow bubbles or fills up with coolant.
I then tried the funnel in the radiator and cracking the bleed but the coolant just starts unloading when it gets hot.
WHAT THE f**k AM I DOING WRONG.
https://www.sau.com.au/forums/topic/476333-m35-coolant-bleed/
Thermostat is part of housing so impossible to get it wrong. I did a full engine rebuild so it was bone dry.
What's weird though is that it will sit on 104deg when driving but if I fluctuate the engine under light load in a lower gear, it will drop down to 93deg then rise back up.
  • 3 weeks later...
I had the same symptoms and came the conclusion it was not a bleeding problem after re-filling the viscous clutch and installing a bigger radiator stopped the overheating. If i had realised the viscous clutch was stuffed first, I wouldn't have changed the radiator unless i could confirm I still had overheating.
So check if you're viscous clutch is ok first (see the link in my sig). I'm still using the 6000cst fluid - never go around to trying the 3000.
Haha funny you say this. I literally just refilled the viscous hub last night with new 10000CST oil and now it moves a f**k tonne of air. Not much was in there.
I figured it had to be an airflow issue as it was hot at 1200rpm but would cool down at 3500rpm
  • Like 1
Soooooo.
I still have the issue and it's frustrating as f**k.
Either the fan is not working when hot or the water pump is not pushing the coolant around enough.
FAN THEORY: After about 1min of high idle it goes from sounding like a jet to a mouse fart and doesn't pull f**k all air in.
WATER PUMP THEORY: If i drive it above 4000rpm in say second at 70kmh, the coolant temp drops 10 degrees in 30 seconds. So I'm thinking that it's flowing more coolant through the radiator, the temp sensor is actually getting more coolant passing over it and therefore getting a better reading.
Although, these two problems are related whereby increasing RPM should increase fan speed and will increase pump flow so it could be either.
Any suggestions or does someone have a spare viscous hub I can try out in Perth?
On 4/16/2019 at 1:48 PM, Sack87 said:
Soooooo.
Chill out mate, its a car everything can be fixed.
Firstly, the clutch fan is suppose to disengage at a certain engine RPM speed. I hope you haven't overfilled the viscous clutch.
I would be getting the coolant vacuum bled. Its a 100% certain way to make sure that its bled correct. Usually I will leave the car on the vacuum pump for a good half an hour before introducing coolant into the system. This is fool proof method.
When you built the motor, did you pump coolant thru the block first to make sure there was no blockages? Generally you would do this when cleaning/prepping the block.
Doing the vacuum bled will also confirm if it has a head gasket leak. May also be worth doing a leak down test.
Figured it out after driving it home in the wind and rain with the temp not dropping at, so it had to be a flow issue and not a fan issue.
I put a VQ35 one in there as it was listed as fitting. Yes it looks identical from the outside but the thermostat itself is different. I never pulled the VQ25 one off my old motor so I had no idea on the difference between them.
The 35 (left) is longer but has a smaller opening, so it's not allowing enough coolant through compared to 25 (right)
  • Like 1
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
