Hey guys,
Car is a r34 GTR.
Car runs perfectly fine, however after around 10-15 mins of driving, engine cuts out and turns off. This could happen while driving, or while on idle at a stop light. Sometimes I can start the car immediately, however most of the times, I cannot. I can turn the key to the on position (dash lights all operational, no check engine light), however cannot start. After waiting a few minutes, the car starts up fine and continues to drive normally until it cuts off again.
I'm thinking maybe a sensor is overheating, and cuts the engine completely. Maybe CAS? Maybe fuel pump relay? I'm not sure.
Temps on the MFD, oil temp, oil pressure, water temp etc are all fine. There's a little fuel pressure gauge in the engine bay, and it looks like it has constant pressure.
Car has a couple of recent mods: Haltech platinum pro, MAP sensors, upgraded cams, fuel pump + relay, intercooler, injectors, fuel rail, upgraded turbos and running e85.
I had these mods for a good month before the symptoms above started appearing.
Any help would be much appreciated! Thanks in advance guys!
If it is a sudden stop it is likely to be electrical.  If it stumbles a bit it may be more fuel.  I once had a Falcon that would just shutdown after fifteen minutes or so - it was heat soak to an old coil.
Can you hear the fuel pump running when the engine stops?
Thanks everyone for the help.
I downloaded the Haltech software and connected the car to my laptop. Monitored everything and realised the MAP sensor was flashing.
Ended up being bad connection to the MAP sensor. We had to re-pin it and now works perfectly fine.
Thanks again! I hope this helps others out with their electrical issues!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
