3 piece forged NOX wheels 20x10.5 +12 off my R34 GTR gloss black dish satin black centre falken tyres front tyres are almost new ,rears are fairly new ,stud patterns 5x114.3 $3000
R34 GTR mechanical non vspec diff 3:545 ratio with nismo 1.5 way diff centre assembled by award diff $2999
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit $1999 hasnt been used since fitted
Brand new high octane racing billet rear driveshaft inserts $1000 or if someone wants a full set $2000
Rare R34 gtr non vspec crown wheel and pinion 3:545 ratio ready for a aftermarket diff centre will fit into any non vspec diff housing will throw in other spares everything that in the container are all 34 non vspec pieces $750
Brand new Plazmaman 85mm throttle body with hdi clamp welded on with s15 throttle cable to suit $750
Brand new Precision 66mm wastegate brand new in box $665
R34 gtr back half of tailshaft $350
R32 gtr front half of tailshaft $250
R34 gtr power steering hardlines with brand
new pressure switch $250
R32/33 gtr drivers side front shaft suits reco $200
2x Geniune BBS LM F1 black and gold centre caps $150
R34 gtr factory wheel nuts full set 20 pieces $50
R32 gtr gearbox crossmember $50
R34 gtr/gtt boot brake light $50
Rb26 bottom timing cover $50
Rb26 backing plate $50IMG_8403.jpgIMG_8404.jpgIMG_8405.jpgIMG_8425.jpgIMG_8436.jpgIMG_8419.jpgIMG_8418.jpgIMG_8420.jpgIMG_8424.jpgIMG_8430.jpgIMG_8412.jpg
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit hasnt been used since fitted $1750 or will swap for r32 33 34 gtr rear brembo kit calipers pads rotors and brake lines with $1000 my way
Brand new Precision 66mm wastegate in the box $650
Brand new Plazmaman 85mm throttle body with hdi clamp welded on ,throttle cable included $600
R34 gtr non vspec crown wheel and pinion 3:545 ratio it will fit into any non vspec diff housing $550 will throw in a housing so all you need is a aftermarket diff centre and off you go
R34 gtr back half of tailshaft $300
R32 gtr front half of tailshaft $200
new pressure switch $200
R32/33 gtr drivers side front shaft suits reco $150
2x Geniune BBS LM F1 black and gold bbs logo centre caps $120
Rb26 girdle $50
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/#findComment-7904902
  • 1 month later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
