boomtheroom Posted May 19, 2019 Share Posted May 19, 2019 Hi All My rear window demister has stopped working.. the light does not come on when the switch is pressed so i thought it may be the switch..however if i unplug the wires going from the switch to the demister module in the rear quarter by the jack in the back i get 12 v from the connector and the light on the switch comes on..plug it back into the module ..light goes back off.. So i unpug the demister harness on the other side of the module (output to the actual demister heater bars) and light comes on.. plug it back in light goes off so im assuming that its the actual demister bars that have an issue..if one of the wires have come off the demister bars it would be like a open circuit? as tho i unplugged the plugs wouldnt it? therefor the light would come on? but it doesnt...any ideas? when the switch is pressed so i thought it may be the switch..however if i unplug the wires going from the switch to the demister module in the rear quarter by the jack in the back i get 12 v from the connector and the light on the switch comes on..plug it back into the module ..light goes back off.. So i unpug the demister harness on the other side of the module (output to the actual demister heater bars) and light comes on.. plug it back in light goes off so im assuming that its the actual demister bars that have an issue..if one of the wires have come off the demister bars it would be like a open circuit? as tho i unplugged the plugs wouldnt it? therefor the light would come on? but it doesnt...any ideas?? Cheers! Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/ Share on other sites More sharing options...
GTSBoy Posted May 19, 2019 Share Posted May 19, 2019 The "module" in the back is a noise suppressor unit. So, it's just going to be a capacitor (at best guess). The fault is probably in there, if it is a big ol' electro cap, it's probably popped its load all over the insides of the box. Here's the wiring diagram. It's not rocket surgery to work out where the pixies come from and where they flow to. Put 12V direct onto the hot side of the demister bars and see if they get warm. Looks like the switch's lamp is back fed off the output that comes out of the switch and goes to the back of the car. Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/#findComment-7905559 Share on other sites More sharing options...
boomtheroom Posted May 19, 2019 Author Share Posted May 19, 2019 ive tested the wire from the switch output that goes into the noise suppressor =12v then the output on the output side of the noise supressor =12v tested the hot side of the demister bars with a ohms test = closed circuit.. does any of that info help diagnose whats going on? Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/#findComment-7905561 Share on other sites More sharing options...
GTSBoy Posted May 19, 2019 Share Posted May 19, 2019 4 hours ago, boomtheroom said: tested the hot side of the demister bars with a ohms test = closed circuit Mark up the drawing with the connection points across which you measured short circuit. Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/#findComment-7905581 Share on other sites More sharing options...
boomtheroom Posted May 19, 2019 Author Share Posted May 19, 2019 measured at the points marked in red with the rear defogger disconnected to the noise suppressor unit Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/#findComment-7905586 Share on other sites More sharing options...
boomtheroom Posted May 20, 2019 Author Share Posted May 20, 2019 any other insites? Link to comment https://www.sau.com.au/forums/topic/477069-r32-gtr-rear-demister/#findComment-7905671 Share on other sites More sharing options...
