Hi all,
I have a few small spraying projects I want to kick off soon. The biggest is a new front bar for my E90.
I'm going to be using an Aldi air compressor and I had some qs about that.
A lot of sites recommend against using such a compressor for doing a whole car but I'm not doing a whole car and I don't really understand why it's not recommended.
If I get a HVLP gun surely I could get a coat in with what's in the reservoir?
The next thing I need to choose is a gun, from my understanding I'll need a 1.3mm tip for clear and base. I'll just use a rattle can for primer.
This guy looks good: https://www.autorepairsdirect.com.au/professional-gravity-spray-gun-pot-1-3mm.html
Would love to open a little chat in here for small budget home spray jobs.
Thanks in advance.
  • Like 1
https://www.sau.com.au/forums/topic/477244-i-wanna-do-some-spraying/
Look on You tube for videos on technique. Important requirement is a dust free environment on a still, windless day. And remember that a nice paint job will highlight  rather than hide any imperfections so preparation is key.
Cheap small compressors are the devils' work. The only way they make sense is if you buy 3 or 4 of them and gang them all together.
Well despite this we bought a gun today. It requires 100 l/min and our compressor will do 270 l/min so hopefully we can get a decent job out of it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
