Located Dapto NSW
Cylinder head – Awesome Condition. Was going to put it on the next time I needed to do timing belt. comes with manifolds, cam covers, injector rail etc. Can sell off individually. $150
S2 Turbo. $150
2x Valley covers – One is pretty immaculate, the other one has a ding in the top. $20 ea
Radiator shroud $20
Intake Box – made out of 3mm lexan. Looks real good when its in. holds a pod tight and points it clear of the light (poetry) Works well and looks very clean. $30
Door trim runners $50
S2 Floor mats – Really good condition apart from a hole where the left drivers heel sits $100
Rear strut bar $80
Skid plate $40
CAS. $40
HKS BO/Recirc Valve. $40
Drivers Window switch - missing switch. $20
R33 Workshop manual.  $20
R34 Vspec2 Pedals - fit r33s also. $100
Boot lining and carpet (only whats seen) $20
Edited by GoHard
https://www.sau.com.au/forums/topic/477300-r33-gtst-sii-parts-nsw/
Boot lining sold
PM Replied and no worries GeeDog, your next in line.
Pick up only please, not interested in posting any of it... unless you REALLY want it SO bad you pay me what it feels worth to you. Its breaking my heart
