Thanks guys, car is at the painters at the moment, as soon as I get it back I'll post some more exterior pics.
I have a couple before and after pics of an LED conversion I did though. And pic of when I got a new ECU and tune down recently.
65865398_381480152496596_6763611199482363904_n.thumb.jpg.dac72ee98f79d34df645807d67d4b93c.jpg
65026352_2381639262047914_3958546033872470016_n.thumb.jpg.4ff1df66b33cdb4a81ba5871d9edf35d.jpg
I just got a membership to SAU as well so hopefully see you guys at some meets/track days ?
  • Like 1
On 15/07/2019 at 6:58 PM, Links said:
Hey Grim - car looks great - what LED's did you use for the dash upgrade?
Hey mate,
I went with:
T10 White 6000k canbus LED for the dash (You need 5)
T5 White 6000k LED for the centre triple gauge cluster (You need 3)
  • 4 weeks later...
Hmm, I could write it up but I wish I took photo's of the process, would have made a much better guide. My car is in a workshop getting a turbo upgrade at the moment but I might pull it all apart and take some snaps for a write-up when I get it back.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
