Hey Gents.
Well, I'm right to make some guides up.
I need to know numbers of people and front bars.
People in buy (front bar in brackets)
ME....................(Nissan Sports).......(DONE AND DUSTED)
ADZMAX............(Nissan Sports)......(DONE AND DUSTED)
RedBaron.........(Nissan Sports).......(DONE AND DUSTED)
ABOBOB...........(Nissan Sports).......(DONE AND DUSTED)
NJR 34GTT........(Nissan Sports).......(DONE AND DUSTED)
MUZ.................(Nissan Sports)........(DONE AND DUSTED)
ALL Nismo Bars are now supplied.
DAZ.................(Standard Bar)..........(DONE AND DUSTED)
NismoR34........(Standard Bar).........(DONE AND DUSTED)
GROUND RUN...(Standard Bar).........(DEPOSIT PAID)
CNBLOW..........(Standard Bar).........(DONE AND DUSTED)
COXY................(Standard Bar).........(DONE AND DUSTED)
Afro..................(C-West Front Bar)..(DONE AND DUSTED)
Eriktufa.............(Top Secret Bar).....(DONE AND DUSTED)
GTTR34............(URAS bar)...............(DONE AND DUSTED)
THAT'S ALL FOR NOW
PRICES ARE $65 as I didn't take into account the cost to get them bent.
BASS OUT
https://www.sau.com.au/forums/topic/47760-group-buy-r34-gt-t-radiator-guides/
  • Replies 175
You haven't put me down yet Bass!
Including me there are already 6 of us, prices should be geting better now :P
+ Abo Bob just needs a little convincing and he may join us too!
AboBOB
Come on.
It's cheap.
Good quality, fully routed, not turret punched. Bent up with love my me personally.
You couldn't ask for a better deal...........
Daz,
R34GTT
Anytime you guys want to meet up to measure your bars is good with me.
I work in Mitcham, and you could come after 5pm if you like.
ASAP would be good.
Daz,
R34GTT
ASAP would be good.
Early next week Peter, I'll ring u to arrange a time.
Cheers
:D
Hey Guys.
I've been called off on Business for the most part of next week.
I fly to Noumea on Sunday arvo and wont be back until Thursday.
I have sent drawings to my subbies who should e-mail the quote back to me early next week.
As soon as I know details I will let you all know.
BASS OUT
No probs, thanks for the update. :)
As for the Skylines Australia being engraved across the middle, I'd prefer mine left blank as I will be putting a few stickers on the top surface anyway.
Looking forward to getting mine! :(
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
