Well I have come across a great deal for all the R33 25t, R32 gtst people out there.
What we have is a pod and cold air box all in one kit. this kit is great cause it requires you to only remove the airbox and undo anything else (pain it the butt) it uses 2 factory bolt holes and the guard to hold its self in place. (see pics)
The box/panel is made out of ABS which is the same stuff your standard air box is made out of so its great for keeping out the hot stuff.
there is no modify your existing engine bay or anything else for that matter.
3 easy steps.
1./ remove your cold airbox etc...
2./ bolt up the adaptor plate and pod.
3./ fit cold air panel/box
simple... yeah well we thought so.
ok dollars simple. email me you details at [email protected] and once I have 10 people confirmed (via payment) we can all buy the for a simple $230 in GST + freight.
if you have any questions please email me.
Cheers
Scotty
  • Replies 99
Just a question, where you getting the air from?
it get the cold air from the front (comes in from behind the headlight ) it basicly blocks the heat from the side and the top which is where most of the heat comes from.
from under the pod.
what kinda pod is it? How would it compare to say an A'PEXi one?
Can you get some larger pics aswell please?
Its a unifilter, they compare very well, plus they are reusable too.
Wash and re-oil etc.. email me for the pics.
INASNT, these unifilter pods are a universal item that have been fitted to a range of high performance cars including skylines without issues.
The partitions are a new design, but are running without any issues (thats my purty blue skyline in the pics). What sort of testing do you mean?
Can you separate the kit?  If yes, what is the cost just for the cold air box?
I am already using a Unifilter Pod and am looking for a cold air box.
Duncan...as above. Will you separate the kit? If yes, what is the cost just for the cold air box?
Hi Swiyo, sorry that we haven't replied yet, we are just checking out with the supplier for a price, I'm sure we can help out.
Have you been running the pod long?
From minor testing guys at ice have done on pod in sealed boxes shows that when you encase a pod in a box the natural intake of air a pod has (all directions) sometimes effect the way fersh air enters it when inside a box. Same as with panel filters are ok in a box as they only suck in air from one directions.
  • 4 weeks later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
