Hey Guys
JUst noticed when the car is running on my r32 gtr and booster activated when i depress the brake pedal it make a wooshing sound like a bellows pump
havent noticed it before..is it normal? or if not what could cause be? brakes seem to be working as normal..
heres a video of what i mean.. ignore the funky slippers....
https://youtu.be/IEztiu6vbZY
https://www.sau.com.au/forums/topic/477716-brake-pedal-noise/
slippers very appropriate for this time of year.
sure sounds like you have an air leak, and probably in the booster itself. In the engine bay there is an air line from the rear of the plenum, through a 1 way valve, into a cannister and then into the brake booster. Check each of those lines for splits and make sure the 1 way valve is working (ie, you can blow air through from the engine side, but not the cannister side).
But I think most likely the booster has a leak. You can replace with second hand or reconditioned one.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
