Well, you could try poking 12V into ECU pin 46 and see if you get 12V out pin 9. It should also idle up when you do that. If all that works then look to the signal that should be coming from the AC controller. If it doesn't work, then ponder whether you've got pin 9 even hooked up! And so on.
If the ECU is broken in some way (not the wiring), you could probably trigger the AC relay direct out of the AC controller, but then you won't get idle up.
the thing is, I have probed every single wire from the HVAC unit whilst turning ac on and off, and I see no change in any single wire from volts to ground. The ac button lights up and light goes away when it is being switched and it shows "ac on" on the display and goes away when it should be off.
Will try that test on the ecu however.
Edited by nicostar
Well......that's a whole 'nother story. Because the AC controller doesn't necessarily just throw the compressor on as soon as you power it up, or even press the A/C switch. You have to have the upstream conditions satisfied. Things like the refrigerant pressure switch and so on.
If you've got borked wiring in other parts of your conversion then all bets are off. You can jumper shit out until it runs and then see what it took to make it happen.
Oh, and in my previous post, where I said "chuck 12V into", I would probe first with a multimeter and see if there is power there already, because if there is then you should supply an earth at that point to make things happen.
ok will check for power from pin 46 and test, pressure appears good and refrigerant is in the system, I don't think the compressor relay would turn on the compressor when given the ground signal from inside cabin if the pressure switch wasn't working, the ac wiring from the hvac unit are intact, only wires chopped were the ones that went to ecu from body loom connector to ecu.
apart from the pressure switch can you suggest what else needs to be working? the only sensor not working at the moment is the outside air temperature sensor according to the hvac self diagnosis.
16 hours ago, GTSBoy said:
Dunno, but seems likely.
well HVAC unit showing code 20 currently which means all sensors ok, ac wires hooked up how they should be through the ecu and nada ac works. still the grey wire for "pin 36" is the only one left out. Also the engine doesn't seem to idle up when power steering pressure is present (locking the steering wheel all the way this switch is hooked up to send signal to pin 19 so no issues with wiring switch is also working) nor when pin 46 is grounded, 12v is present in pin 46. I've read somewhere that a bad o2 sensor can cause idle to not respond unless you plug it out or replace it, any advice would be good, I am hoping that is the reason why ecu won't idle up when ground signal sent to pin 46.
In the RB20DET engine loom the O2 sensor wiring runs with the PS switch wiring. I had the O2 sensor cause the wire to burn, which damaged the PS wire which left me with heavy steering. They are not related electrically in any way except for the fact that they run side by side.
can you explain run side by side? which wire goes into which? o2 sensor has 3 wires (power, signal and ground) the ps switch has 2 (one side grounded and the other continues the ground when switch is closed)
oh ok, well in that case the wiring for the both are fine for me, would you happen to know if the ac control unit has a ac switching signal that you can see a change with a volt meter or test light when ac button is pressed on and off?
Also if I put a ground to pin 46 shouldn't pin 9 send out a ground to the compressor?
I have an R32, so I have an R32 AC control unit, which we can see from the wiring diagrams above does things a little differently to the R33 one.
I have an R34 ECU, so the pins are all different to both of the above. And, getting the AC to work after the engine transplant was a major exercise. We had to do some things with relays and other tricks with the pressure switch. So my car is not able to serve as an example that I can measure stuff off for you.
Further to that, You should put a multi-meter onto the terminals in question and determine if they have 12V or ground on them, before trying to put any 12v or ground of your own onto them. If you put raw 12v onto a terminal which is continuous to ground, you are making a high current short circuit and can fry shit. Similarly, if you simply ground a pin with 12V on it, you can be making a short that will burn shit up. You can also use a test light to see what's what on those terminals. Close examination of the wiring diagrams can also inform you of which way the ECU terminals are most likely to work. They USUALLY act as the earth end of a switching circuit. But some do not (like some of the fuel pump outputs.)
unless earth doesn't mean ground anymore, I am fully aware of what happens when + meets -
I do have an idea how the ac should work
I currently can't get it to work and just need some advice. At this point I am unsure I will find that advice here. Thanks for trying to help all the same mate.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
