SAU Dyno Day At Unique Autosports - Saturday August 21st
  • Replies 183
Are you kidding?1?1?1
Theres gotta be an extra 40kw at that thar pod! :P
omg r u seereeus? fully sick bro i'll leave my pod on den. :)
nah seriously, I don't have a cold air partition so it looks fully sick but I guess the heat soak doesn't do much for it.
Nick can you change me from competitor to spectator please. Im waiting on a set of Splitfire Coils to arrive which I was hoping would be today but looks like it'll be next Monday.
No point putting my car on the dyno when it was on only 3 days ago with a dyno graph that looks worse than a rollercoaster ride.
I probably won't be able to make it tomorrow either due to having to make an unexpected trip to the dentist...stupid fillings!
If it doesn't take too long, I may still rock up and see if it's possible to put the car on the dyno or just to have a look see if there isn't any spots available.
Sorry for the inconvenience.
Thank you John and all the lads at UAS as well as our friends from turbosmart for there support.
Big thank you goes to SAU offical for helping to organize the day and for there effort to get all cars onto the rollers.
Was a great day..
does anyone know where I can get 2.4kw stickers from:D
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
