Just a quick question, im getting about 380-410km on a full tank of fuel. and did about 200km on 32L of fuel which is quite high compared to my mates. he gets around 600km on a tank of fuel. So is my fuel needle off or is this just normal? Its an auto btw but use the semi auto (manual option) to drive.
https://www.sau.com.au/forums/topic/477935-v35-fuel-economy-problem/
Very common that the fuel sensor is dirty.
There are some Topics on this if you go searching
So if you find that when you fill up your tank (to the top) the fuel gauge doesn't go up and past the full line. You may need to clean the sensor.
Pull off the lower part of your back seat to get to your fuel tank pumps.
there will be one on the drivers side and passengers side. open both. pull out the pumps. get a cotton tip and clean the metal contacts.
Best to find the topic on this. there are pics ;)
  • Thanks 1
are you basing your figures on how much fuel you are actually putting in the car?  or what the fuel gauge says?  Fuel gauges are usually not accurate enough to use for judging economy when they are working well.
Fill the car, reset the trip meter, drive for a few hundred KM then fill the tank again, you can then work out your economy based on the distance you travelled and the amount of fuel used.  My 6MT is usually in the mid 10L/100km with 100% light urban driving and mid 7s on the highway.
If you are really only getting 200km from 32L of fuel, this is quite bad, coming in at 16L/100km unless you are almost always in heavy peak hour traffic.
I was having similar issues with my v36. Was getting about 300-325km per tank.
Annoyed me enough to do the following
Cleaned MAF Sensors, Replaced filters, Reset ECU
unsure if the ECU on the v35 is "self learning" like mine but when you reconnect it all, Drive in (D) only for about 50km (drive like a f**king grandma, slow and steady)
I did this and now i get atleast 500 to a tank. i got 700 on the highway before i filled up.
Also as fun as it might be to drive in Tiptronic, it will make your economy worse. I only use it every now and again.
I did that and drove for 200km then used that info with the L filled up and got 15L per 100km. But if that’s the case would that mean i can drive past the Empty (E) o the fuel gauge since its inaccurate. ?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
