Roooooound Twooooo of "Guess that Car"
Nissan Leopard...
I win again!!!
Hahaha! Strutto's some kind of Japanese car freak... well done again :cheers:
Well that was quick... eeeerm, thanks to all those who participated... good night!
Talk to Strutto... he must have some Japanese car almanac or something where it's got clear pages with the outline of every single Japanese car from the 70's onwards, and he just puts the clear page upto the monitor and sees if the photo matches the outline... instant winner!
Uh oh... He's on to me.. :Oops:
Three in a row and you get a free set of aero mirrors isn't it Rezz?
Rezz? :headspin:
:bahaha: good one Rezz
strutto or rezz.does this car feature the vg20det ???
It comes with a VG20E, a VEG20ET, a VG30DE or a VG30DET...
Strutto: free set of aero mirrors? If I wasn't homeless, maybe I could entertain that idea!!! :P
Looks like the HKS DRAG Driver (kawasaki) and HKS DRIFTER (Nobuteru Taniguchi) with hair loss... ;)
Bwahahahahahahaha!!!!! Priceless! :):D:D
[/size]
I hope Troy doesn't see your post...
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
