HAHA you are not a true import driver in victoria until u get canaried!!
Welcome
If that's true, maybe i should sell my line.
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR. Lets see who's worthy on the track, you dyno queen! ;):)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967605
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR.   Lets see who's worthy on the track, you dyno queen! :D:rofl:
when i have a license again i will be out on the track :D
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967732
You will need to get a standard BOV for removing that canary.
A switched on VICRoads person will pick you up for it.
If you know the tricks then vicroads wont even look at ur car when you go to clear a canary so you dont have to take anything off. :D
I have explaining this so many times before
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-968505
Obvously his trick is someone on the inside
An INSIDER...ive heard if urve got a mate who works for vic roads...you can get off scott free everytime
yes if you know someone at vicroads then you can get the canary cleared 5 mins after the cops give it to you, but that aint my trick, and i dont have a trick either, its just a way of going about it, no tricks involved :)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-973350
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
    • Hi guys,  I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop. It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.  Any ideas what could be causing this?
    • How does dead head help with emissions? Is it being claimed for emissions because fuel in the tank isn't being heated up by being pumped around, hence should condense more? One part that is a negative about dead head is heating the fuel at the rail a lot more (IE heat soaking at traffic lights) and this causing lean outs on takeoff afterwards. If my thoughts above are correct, I wonder how different the tail pipe emissions become with the lean outs vs less fuel tank emissions into a charcoal canister
