HAHA you are not a true import driver in victoria until u get canaried!!
Welcome
If that's true, maybe i should sell my line.
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR. Lets see who's worthy on the track, you dyno queen! ;):)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967605
On the other hand; having a big turbo hanging off the side of your RB does not make you a true import driver, just like owning a GTR does not mean you can "drive" a GTR.   Lets see who's worthy on the track, you dyno queen! :D:rofl:
when i have a license again i will be out on the track :D
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-967732
You will need to get a standard BOV for removing that canary.
A switched on VICRoads person will pick you up for it.
If you know the tricks then vicroads wont even look at ur car when you go to clear a canary so you dont have to take anything off. :D
I have explaining this so many times before
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-968505
Obvously his trick is someone on the inside
An INSIDER...ive heard if urve got a mate who works for vic roads...you can get off scott free everytime
yes if you know someone at vicroads then you can get the canary cleared 5 mins after the cops give it to you, but that aint my trick, and i dont have a trick either, its just a way of going about it, no tricks involved :)
https://www.sau.com.au/forums/topic/47903-canaried/#findComment-973350
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
