WTB - Transfer Case Steel Ring / Friction End Plate
Hi Everyone
I'm in a bit of a pickle. I need the end plate in the transfer case. Circled in the picture.
These steel plates come in various sizes to set the clearance. I need it to be 6.7mm / 6.8mm thick.
Can anyone help? I will pay up front and need it to be posted fairly quickly.
Thanks
You will not get this quickly. These are special order part from Japan, we've done heaps of transfers and wait time is at least 8 weeks generally as they are made up from Nissan. Also needing to go to 6.8mm on the front retaining plate (31537XA) suggests that the rest of your friction and / or steel plates are excessively worn, as we've never needed to go past 5.2mm - 6.2mm, and that's using the standard 7 friction plate or modified 10 friction plate arrangement. These plates go up in 0.2mm increments from 4.8mm - 7.0mm, so a 6.8mm is definitely not the norm.
The rear retaining plate should always be set to 5.0mm (31537X). Are you checking clearance correct as in, you have the Attessa actuator with piston installed in the back ? If not it gives an inaccurate and much larger clearance, which should be between 8 - 20 thou (0.2mm - 0.5mm) between front retaining plate and retaining circlip.
I have some front retainers from 5.8mm - 6.2mm and lots of the steel plates, but if you definitely need the 6.8mm retaining plate the original part number is 31537-05U10 which has now been superceded with 31537-1P410 and is about $90 -$110.
For any other thickness the part number changes with the last two digits from 00 to 11, so a 4.8mm is 31537-1P400, a 6.0mm is 31537-1P406 and a 7.0mm is 31537-1P411.
Hope this helps.
Hi BK!
Thank you very very much for this long and informative post. I am going to double check with my mate that is rebuilding the transfer case and see if there is something wrong. I am building it with the new arrangement (most aggressive, s/f/s/f/s/f/s/f/s)
I already have a 5.0mm and 6.2mm retainer, but he thinks he needs 6.7mm.
I have purchased brand new friction plates, but have reused the steel plates. Maybe that is the cause of the large clearance - re-using the steel plates?
What are the steel plates meant to be thickness wise?
Thanks again mate, I really appreciate this input.
OK so you're doing the 10 plate mod. Can't remember the steels off the top of my head but they usually don't wear bugger all (less than 0.05mm), UNLESS the wrong oil or low oil has been in there. Castrol Transmax Z is the best, I'll measure one later to confirm steel thicknesses, but very rarely need to replace the steels. As above the clearance is 0.2mm - 0.5mm, and they only come in 0.2mm increments so there is no 6.7mm.
Buying new plates has generally decreased the clearance required, so it shouldn't be that.
As mentioned above, very important - make sure the clearance is being measured with the Attesa actuator installed with piston in. This is a must or else your clearance will be wrong (on the large side).
Yeah that is it I am pretty sure. (I am just a dumb tuner, I'm not doing this, my friend who is a mechanic is lol )
This is a donor case so I have no idea how it was treated before I got it. It's from a R33 GTR so it is possible someone stupid was pulling the fuse and doing skids not knowing these have preload.
I have only used Transmax Z in both of my GTRs transfer cases so glad to hear that.
This one we are building is for a circuit car hence the 10 plate mod.
He has also assured me that he is measuring it with the Attesa actuator installed with the piston in.
Just curious, when you say "piston in" does that just mean the actuator bolted onto the back with no hydraulic pressure? (at rest if that makes sense)
Image result for attesa actuator
Yes, the actuator bolted on the back of the transfer with the piston rod for it also installed with no hydraulic pressure on it. This is the real disengaged state. It does make a difference to the clearance, and the Nissan manual also mentions to check it like this. If you don't do this and measure it, reset to the 0.2mm - 0.5mm clearance with the actuator not installed, then bolt the actuator up the transfer case will be permanently locked to some degree, drag the plates and destroy them.
I just asked him and he said that is exactly how he has done it.
I guess now all I need to do is measure the thickness of my steel plates and see how much they are worn.
If you have some there and can give me a measurement that would be great :)
4 minutes ago, BK said:
I'll look into it. More importantly, what is the measured clearance now ?
He says it is 0.9mm at the moment.
I'm starting to think my steel plates are all worn that slightest amount. All the friction plates are brand new.
Just to add to this mate - I contacted Kudos Motorsport earlier and they said the plates are 2mm thick.
He has 12 in stock so I might be able to grab some if they are the issue.
Thanks for your help though.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
