Hi Guys
I have a series 1 r33gtr. The original problem was a valve guides broke and went ontop of a piston so while I had the motor out I replaced main bearings rings freshened up pistons replaced all gaskets replaced oil and water pump, I had the head rebuilt with stronger springs installed. Now I have reassembled the engine and installed it again but for some reason I have lost all boost (turbos spool up as usual) and also noticed that I have lost water from the radiator. I have checked all water lines and no mixture but when I removed the oil it was milky and found my water. It's not mixing in the water lines tho. Could anybody point me in the right direction please..
Thanks in advance..
2 minutes ago, Justinr2911 said:
I honestly didn't think of doing that cause it was running perfectly before the valve guide let go.
Really need to disassemble head from block, inspect head gasket carefully between all water and oil gallery sealing surfaces, if ok, take head to be pressure tested. Sorry for your troubles mate, its always a bastard when this sort of thing happens after a rebuild
  • Like 1
Also head gasket is a new MLS gasket.
The most common failure of MLS head gaskets is poor surface preparation. MLS gaskets cannot conform to surface irregularities outside of their stated specification which is usually 20-30 RA (Roughness Average). I personally don't use them, My 30/25 has a genuine RB26 gasket and never had a problem.
Thanks heaps I have found someone selling a new genuine head gasket might grab it.
Head is off now I’ll have to wait till next week when my head guy comes back lol. He’s gonna love me he hated down the head the first time ??
  • Like 1
Amayama sell them for $100 delivered delivery around 2 weeks. Part number 11044-05U16
Edited by Rusty Nuts
Oh sweet thanks heaps
Just called the head guy $71.50 for the pressure test. Also need to replace the oil cooler on the side of the oil filter housing just to be safe aswell as exhaust cam cause some idiot snapped the key for the CAS. ???‍♂️ Lol.
I was also thinking of rebuilding the turbos while they are off could you recommend a good company to get the kit from?
Thanks heaps for the help man..
43 minutes ago, Rusty Nuts said:
Yeh, The oil warmer can fail but you usually also get oil in the radiator, I have'nt rebuilt GTR turbo's maybe another member can jump in here with a recommendation.
Thanks Rusty
  • Like 1
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
