19 hours ago, xmanz said:
ok that sounds not too bad is the timing cover one piece or is there a top section thats not behind pumps and  things...
btw i had a search for v36 workshop manual  and g36 for 2007  cant locate any ideas
https://ownersmanuals2.com/d/52111
2008.
pretty close
  • 1 month later...
update on my troubles
mechanic checked all the cooling system over..no apparent issues
went to next stage took throttle body off and compession tested it and then a leakdown test ...........both no issues
he then put back together and vac test the system    no issues\
He is a bit stumped but did say maybe the water pump is sucking air behind the timing cover  anybody seen anything like this???
he said there where bubble coming up on compession test on any of the cylinders.....    is it possible to suck air in somewhere else?
thank you
thank you
Could you rewrite this sentence please? Its a bit hard to work out what you are saying.
Did he say yes there were bubbles in the radiator when some or all of the cylinders were compression tested or no there were not?
BTW you're out on a limb in Napier - I have good contacts in Auckland but none there... and yes you  have to pull the front of the car off to get at things which is why replacement timing chains are so expensive...(so if you end up doing this good idea to have the chain and chain guides checked at they are a weak pint on the VQ25).
He infered to me that winding it over doing compression test  he saw bubbles   and no matter which cylinder he did  he saw bubles these are not fine bubbles but  like a burp      btw  v36
i got the g35 manual
Ok one more question...did you watch the mechanic do the pressure test and what happened? Did the pressure go down without any sign of water spurting out?
Here is a test kit along the lines of what GTSBoy was suggesting earlier (you may be able to get a similar one cheaper from your local Repco or Supercheap) that you can use yourself:
https://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/other/listing-2596027845.htm?rsqid=e736fd9eb1f5494eb91b42a7ed009919-001
If this test comes out positive you have a problem. If it comes out negative (no exhaust gas in bubbles) then it is still possible you need a good bleed of the air in the system (especially if this problem arose following a service where the coolant was changed).
OR you do a good bleed now anyway: Get the front of the car as high as possible (up a steep drive, on a set of ramps, or jacked up as high as) and also find a plastic bottle (coke , milk, anything with the bottom cut off) the neck of which will fit tightly in the tube after you have taken the radiator cap off. Start the engine and turn your heater(s)  on full. Idle until the thermostat opens (you can tell by the hoses  heating up) and add water to the plastic bottle (half full will do). Continue to add water if necessary and watch for the bubbles to stop. Give it a good 20 minutes or so. If the bubbles stop put the cap back on and hopefully its cured!
BTW as a matter of interest how far can you drive the car before it overheats?
+ also open all bleed screws that you can find to get air out of trapped spots. RBs have a couple, I would guess that VQs probably would too. YOu don't just open them and leave them. Open and close them regularly while you're leaving it running to bleed up as above. Bubbles will collect at the high points as they come around the system. The screws give you the opportunity to get them out.
i didnt see the test but he said the compression was i think 190 on all no loss  and the leakdown  no issues,
btw thank you for all the info much appreciated       also the car has never overheated just hear bubble sound form behind dash when i started the car..upon opening bonnet the resivour was pretty full......so ill try the bleeding  scenario
Ok with lockdown cant get a co2 device but i sloped the car, filled the bottle half full sealed onto radiator,,,,,youl see vid 1 which is 5 mins in     video 2  12 minutes in   and video 3 20 mins.
i guess my dumb mechanic didnt do this as youl see by vid 3  it shows what i presume is indeed compression/exhaust gases into water/////   Thank you for looking, the coolent did have a bottle of some  hoodoo in it to hopefully plug leaks by mechanic,,,   last vid is when engine is switched off...
Edited by xmanz
Close it up and drive it. If it has not been overheating just keep an eye on the water level. Certainly wouldn't be pulling it apart at this stage. Worth doing it again to see if it gets less. If not definitely do the gas test. You may be able to get a kit from Repco or Supercheap on line as they are allowed to ship "essential" items.
i have to mention also  power is down and uses more fuel that what it used to....  i may want to sell in a year or so and i cant sell this..lol
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
