Hey, I have a 94 r33 gtst manual skyline. My brother has just bought a VN ss. ive raced him and kicked his ass, but only when we were rolling at 20kmph. his is an auto its got the usuall mods like exhaust and extractors. So how do i take off so that i kick his ass, i know that if i get a good start, all he will see is my nice big round tail lights, but if i stuff up than ill have to chase him down, which i know isnt a problem i just wanna smoke him at the lights, cos hes a commonhore lover and skyline hater. Can anyone help? do i just drop the clutch at say 2200 rpm, or is there some other way. Please help? I was practising tonight, and al i got was alot of wheel spin, i got like 2 good take offs from like 8. What are some tips that can help me take off without bogging down or lighting up the tyres, cos my brother has been running round sayin that he can beat me, only cos i bogged down once and didnt bother to chase him. PLEASE GUYS HELP i wanna show this tree huggin commonhore lover of a brother that skylines are the bomb, and that his crappy VN SS AUTO is a BOMB. :wassup: :rofl:
https://www.sau.com.au/forums/topic/48032-how-to-launch/
Guest two.06l
i hope this racing was done on a private road or at willobank as street racing is not condoned on this site
https://www.sau.com.au/forums/topic/48032-how-to-launch/#findComment-967840
practice practice practice.
buy new clutch.
practice practice practice... and so on and so forth.
Ideally you want the hardest rev you can drop without wheelspin.. add about 200rpm and adjust clutching accordingly.. (basically what was said above cept another way of thinkigna bout it).
Then just practice as you go along.
https://www.sau.com.au/forums/topic/48032-how-to-launch/#findComment-969635
1 = Start from behind, never alongside
2 = Hold it against the handbrake
3 = Take up the clutch till it bites a little
4 = Idle up to 2,000 rpm
5 = Roll off the clutch slowly and add accelerator at the same time
6 = Minimal wheelspin by throtttle control
7 = Close up to the rear in first
8 = Change into second at 7,000 rpm
9 = Pull out and go past
10 = Make sure to sound horn and wave bye bye as you speed past :wassup:
The object is maximum embarrasment, do it once, laugh about it afterwards and he won't race you again. Offer to do it once more if the fool persists, but tell him you will give him a bigger head start this time as he needs all the help he can get. :)
https://www.sau.com.au/forums/topic/48032-how-to-launch/#findComment-971507
I launch at 4200rpm.. But its an RB20DET lol.. :)
Slipping the clutch is the key.
You probably have tyres that are shot by the sounds of it. Either that or you diff is open wheeling.
I've loaded up against the handbrake a few times.
It works well and gives you a clean launch but by the time I click second I always get clutch slip..
Thats my crappy 2.5yr old clutch though. :)
https://www.sau.com.au/forums/topic/48032-how-to-launch/#findComment-972064
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
