Bit of a strange one here but I am trying to identify which are the correct CAS wires at my ECU.
(My S1 Stagea has the 0v300 ECU for which a pinout is basically non-existent. Some wires match with the R34 GT-T ECU but some do not, most importantly the CAS wiring for Home and Trigger. I'm trying to wire in a Haltech Elite 2000 and I'm stuck on these ones.)
I'm a bit of a noobie when it comes to ECU wiring I will admit, but I have a lot of history with general car electrics. I thought this would be a simple case of unplugging the CAS plug, sticking a wire into it, running the other end of that wire into the cabin and checking for continuity between that and any/all of the ECU plug pins. When I did this I couldn't get any continuity readings from any of the 4 CAS pins across every ECU pin.
I'm thinking I might have over-simplified the process and hoping someone here could help confirm a couple of things:
- Where do the wires from the CAS actually go before going to the ECU? From the overall R33/R34 wiring diagrams it looks like it should be a straight connection. between I notice one of the colour of wires at the CAS plug do not show up at the ECU at all (peach) and the 2x thick green wires which are meant to be the CAS Home signal at the ECU are not present at the CAS plug itself either
- Does the ECU have to be plugged in to get a continuity signal? I.E. me unplugging the harness could have interrupted the signal? Do I just pierce the back of each wire with my multimeter probe?
- Same question for the CAS itself - does it need to be plugged in?
Thanks
https://www.sau.com.au/forums/topic/480888-chasing-cas-wires-at-ecu/
Thanks mate. Interesting that you said it needs sensor ground to crank. That would probably indicate that the ECU harness would need to be plugged into the ECU for my testing as the sensor grounds all come together there don't they? Might have to get some better probes that can better pierce wire insulation.
I have the metal Mitsubishi CAS... and I've looked at that diagram A LOT over the past few days but it doesn't help me identify the specific place on the ECU the wires come out. That's why I'm trying to check continuity of wires between CAS plug and ECU to figure out which one is which manually. I was hoping there was an easier way but it doesn't look like it.
The trigger wires you need the 12v, gnd and the trigger + of each to the trigger 1&2.
It may seem confusing as there is separate wire for cam and crank with all the wires as most people go to a full trigger kit but if you look at the diagram power and ground are the same pins at the ecu
Are you running a whole new loom or using the factory Nissan loom?
Use the link ecu help file for factory ecu pin out at factory ecu side but easy enough to find with multimeter from cas to ecu
Thanks
OV300 is the most common ecu
pin44/45 trigger1
pin46 trigger2
earth can be anywhere e.g.32
  • Thanks 1
pin44/45 trigger1
pin46 trigger2
Thanks Kiwi. I was so sure that the 2x CAS 120 wires I needed had to be green as per the excel doc floating around, that once I saw them I decided they were it. Circled in pic attached.
I see now that I was a whole block away from where I should be looking... and the fact they weren't next to each other, but on top of each other was making me think my wiring was all messed up... the black/red wires next to each other (44/45) and the and peachy wire (46) do look correct now. I'll splice into them when I get a chance and report back. Thanks!
I'm still unsure how to test continuity though (just for future things like this) and I'm gonna keep trying to verify as I feel it's a pretty handy skill to add to the list!
Ya live, ya learn ?
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
