2 minutes ago, joshuaho96 said:
It's much harder than IM240 because you have to do both a temperature controlled cold start portion of the test, then kill the engine for 10 minutes after the stabilized phase then restart and redo the first 505 seconds of the drive cycle again. A stock RB26 fails the test pretty badly. There's also a shed evap test that the car has to pass.
The performance standard is whatever the CARB minimum standard was for the year of production, in this case it's tier 1 which means 0.31 g/mi HC, 4.2 g/mi CO, 0.6 g/mi NOx in the FTP-75 test. It takes a set of two catalytic converters in the front pipe as well as a double catalytic converter where the main cat goes, on top of various little adjustments to things like base timing and weirdness like an fuel filler restrictor to keep people from trying to put leaded gasoline in the tank.
I was looking into things like VCAM step 1, secondary air injection on cold start, more modern injectors at higher base pressure, stepper motor controlled wastegates, stuff like that to try and get emissions down but I realized even if I could prove that everything I was doing was to reduce emissions I would never get past the smog referee because you're not going to pass with a standalone.
Okay so this is the kicker then - You're doing a test where the stock 26 won't actually pass.
Funny thing is though, you therefore need mods in order to pass the test, effectively mandating an aftermarket ECU. I found it all pretty interesting tuning the car on the emissions dyno, watching pollution in real time. That said, certain regulatory bodies don't give two shits if they say contradictory things like
1) The engine will not pass stock
2) You are not allowed to modify the engine.
I suggest putting a LS into it, it makes for a better engine than a RB26 anyway ;)
Though this does or may explain why certain LS's have AIR pumps in them whereas they don't have that here.
29 minutes ago, GTSBoy said:
I thought R33 GTR was same as 32. My bad.
Just put R33 lid on 32 ECU?
Cheeky, probably would work too if I'm honest.
There are definitely contradictory directives at play here, part of the "fun". I believe remapping the stock ECU in a non-tamperable fashion is ok, they just don't want you to be able to change the engine map at will. And even if you somehow convinced Haltech to make you a special snowflake version of their ECU with some efuses and map integrity/encryption to keep yourself from being able to flash an ECU map I doubt that it would actually satisfy the state referee because it's still not a stock ECU at the end of the day.
The ridiculous part is that after initial registration you never see a smog referee again in most cases. And these are OBD1 cars so the only test is a tail sniffer shoved in the exhaust while revving to 2500 rpm in neutral for AWD cars, 15/25 mph roller tests for RWD/FWD.
Edited by joshuaho96
This makes me super depressed to go back to California.  I hear it also costs about $10k (USD) for the compliance work and takes up to 6 months since there's only like one lab that can do the work (my information is a bit old though).  Reading all this though, I would rather just stick the OEM ECU back in and put the car back to stock for the compliance work.  Great information here and you should open up your own import business and compete with Top Rank who seem to dominate importing to California.  My understanding is that the 1995 GTR, or any car really, will be able to go into California unless they came with OBD2 (1996+).  I have heard there's a loop whole where if you register the car in a different state for 1-year then you can bring it into California without having to do the compliance work (this may be a myth though).
Going back to parts though, is it safe for me to install the RSR equal length front pipe and HKS Cat back on OEM ECU with my already installed HKS Hi-power?  sorry for going back to this but I want to hear the car sing through the mountains to Hakone and Fuji Speedway track days before going back to the US.
Thank you all again for the constructive discussion on this complicated topic of regulatory compliance.
Your 10k estimate is still current, hard to say how long it'll take. I just learn this stuff so I can make sure I can do what I want to the car, I'm not too interested in getting into engine calibration.
The loophole of living in a different state for 1 year then returning was closed, doesn't exist anymore, that was maybe true 7 years ago but definitely not now.
You can probably do the front pipe + catback without issues on the stock ECU, just make sure you aren't spiking boost too high.
Thanks so much for the input!  Gosh $10k is a chunk of money but I bet the value of the car will go up that much or more.  I just hope it's not going to be super hard to protect the car from theft, or worse, getting car jacked.  Probably not going to be many R33's in California.  I appreciate your first hand experience and wish you the best of luck with your journey through compliance.  Also, I appreciate the clarification on the loop hole being closed.
I think I'll go ahead and install the parts and just watch the boost gauge.  Last thing I want to do is mess up the engine which is in stellar shape and runs like a champ.  Or I may just buy a Power FC for cheap and run that for safety.
Thanks again!!
I'm paying much more than that right now to get my R33 restored and with the ridiculous appreciation these cars have seen in just the past 2 years I would probably stand pretty good odds of being able to recover my money if I sold it.
Theft protection is tough, my general recommendation is a GPS tracker and a transponder immobilizer.
Totally understand man. Restoration, especially body work, is hella expensive. I'm trying to get all the goodies and that stuff done here as I imagine parts there are even more. The ways these cars appreciated in value did kinda take the fun out of it. I like the idea of a GPS tracker and immobilizer. Maybe when you're all done you can share your California r33 wisdom with me. Thanks again man and stay safe.
Yeah, honestly I would prefer if R33s didn't spike quite as hard in price, I think speculation is driving a lot of the price increase.
I still need to find some way of getting my hands on an Autowatch 573, it's been reviewed well and seems to do exactly what I'm looking for:
From there I think a Trackmate GPS unit hidden somewhere in the car should work, maybe a tilt sensor too to notify me if the car is getting towed instead of relying purely on geofence. Of course the important part is to actually keep the car in a secured garage but thankfully I won't have trouble with that.
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
