Hi there, I have a hr31 and I'm looking to replace the igniter and coil pack loom. When I search the part number from the igniter in my car it comes up with a 300zx zr32. I read that the zr32 and red top igniter are the same. Is this true? And if so will that work on a silver top engine or should I buy a different one? Any help would be great i just want to make sure I'm buying the correct thing.
(I'm not sure what loom is in the car but I'm assuming if the igniter is for a red top then its the original one also has the red top ecu)
https://www.sau.com.au/forums/topic/481495-rb20-igniter/
On 14/11/2020 at 12:52 PM, TurboTapin said:
As GTSBOY has said, I would also take the opportunity to upgrade to integral igniters. If you want something on the cheaper end; use newer S2 coil packs like spitfires or OEM.
Cheers.
With putting in coil packs with integral igniters do I just remove the current igniter and put in the different coil packs and section of loom to suit?  Thank you both!
https://www.sau.com.au/forums/topic/481495-rb20-igniter/#findComment-7943221
Yes, essentially. The original wiring from the ECU will currently go as far as the igniter, then the coil loom runs from there to the coils. When you go integrated coils, you basically have to patch in the ECU wires that would have triggered the old igniter to now trigger each coil's igniter (so straight through) and clean up the power supply and earth stuff. There are guides available, but the fine detail depends on which car you're doing it to. They're mostly the same, but don't go trusting wire colours - trust terminals.
10 minutes ago, Eva_hr31 said:
Also as far as I can tell it has splitfire coil packs but do only specific ones have the igniter built into it?
Splitfires are direct replacements for whatever the engine originally had. RB20 and earlier RB25s were all dumb coils with the external igniter pack. Later RB25s and Neo25s have built in igniters. They don't even physically swap from engine to engine, because the coil mounting brackets change. You can see what Splitfires go with what engine by looking up the model number (say SF-DIS-001) and it will tell you what it suits. There are several models across the RB20-RB26-RB25 group of engines.
Splitfires are a good easy swap and used to be the only game in town. They were probably never really any better than the OEM coils - they were just available new when OEM ones were old, burnt and cracked. Someone has done you a favour by putting them in there, and if you do follow the recco to replace them to banish the igniter, at least you can try to sell them for a few bucks to offset the cost of the upgrade. It's not as if you likely need to be replacing your coils. But if you're going to pay for a new igniter.....I know what I would be doing.
  • Like 1
  • Thanks 1
https://www.sau.com.au/forums/topic/481495-rb20-igniter/#findComment-7943223
That makes sense thank you so much for your help!! I'm definitely going to look into getting rid of the igniter it was something I wanted to do anyway but wasn't sure if it was to much of a hassle thanks again
https://www.sau.com.au/forums/topic/481495-rb20-igniter/#findComment-7943311
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
