Hi all,
Going to clean out the garage since the car's going to be sold soon.
First item for sale is an R34 GT-T Turbo that has been fitted with a Garrett GT2530 B/B core. It's in excellent condition with no shaft play, chips, dings or the like.
With this turbo fitted to my stock engine, I was making 207rwkw at 1.1bar.
Only replaced it because it became restrictive after the rebuild with the head work etc.
Works great on a stock RB20DET. :D
Price: $800.00
If someone can tell me how to or post pics for me I do have 2 pics.
https://www.sau.com.au/forums/topic/48181-r34-gt-t-gt2530-hybrid-turbo/
OK all, I've received 8 pm's in like 15 minutes so I'll try to make a few things clearer. The turbo's done about 1,400km's since new core fitted, peak efficiency is 1.3bar I'm told, does not come with a wastegate actuator and requires an ADJUSTABLE one to be fitted. Does not come with fittings and lines either but if you want the accessories that I do have to make a sort of package ( Turbo, Water fittings, Oil Pressure Line and Fittings, Oil Drain pipe/hose and HKS actuator ) the cost would have to be $1,100 plus shipping if required at your expense.
For $800 you get the Turbo with the compressor outlet pipe. Sorry for the confusion.
To ALL of you, I'll be off line from 3pm today until Monday arvo ( don't have a computer at home ). Over the weekend I'll try to get ALL the bits and pieces out and take pics so you can see the package, not just the turbo.
If anyone can post the pics for me please let me know :D
Guys,
I'm very sorry I've not yet been able to get back to you all until now but the turbo is pending sale and I'm just going through the final stages of sale at the moment. If the sale falls through for any reason I'll let you all know.
Cheers.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
