Hello all, wondering how I would go about doing rust repair on my r32 gtst.
Pinch welds were bent in by a shop and I tried to bend it back with some vice grips and scraped alot of paint off to reveal rust forming behind where it was bent in. I just sprayed a gel-like rust protection coating on to try to slow it down, but I'd want to completely sandblast it off
. Thank you in advance.
https://www.sau.com.au/forums/topic/481868-rust-on-sills/
Fortunately it doesn't look too bad. I would just get a wire wheel on it and take it back to bare metal, clean it up, then get some rust protector (POR15 or similar) on it and cover it with some underseal.
The most worrying part would be whether the rust has gotten in above the pinch welds. In which case it will need professional help - cutting, welding etc.
https://www.sau.com.au/forums/topic/481868-rust-on-sills/#findComment-7946520
Lift your carpet and remove the plastic being held in with 3 screws. Both my inner sills exactly at the same spot had decent rust due to this. Somewhat easy cut & weld job though. Cheers.
Edited by TurboTapin
https://www.sau.com.au/forums/topic/481868-rust-on-sills/#findComment-7946547
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
