Hello,
I have a full stock r34 gtr however the brakes locked.
Brakes are fine (pedal feels good), I had to go over 90km h under rain to make it locked.
no brake leakage and brake fluid level is ok.
I'm using used (good conditions) winter tyres.
abs goes on and off after ignition is switch on.
I had a fault code 72 that I clear and it didnt get back.This fault code was relating to TPS (MFD show correctly the TP) I also checked the TPS signal on the abs connector and voltage is within spec (0.5 - 4v)
I checked the wheel sensors from the connector of the abs module I got values (using a cheap chinese ohmeter) between -0.5k and +8k (depends at which speed I turn the wheel ) with average/rest at 1.2k
during the wheel sensors signal measurements; I moved/shake the wheel sensors wires/connectors to make sure there is no short or open in the loom/connector/sensor.
I'm out of idea ? can it be a relay ? fuses ?
best regards
https://www.sau.com.au/forums/topic/481886-r34-gtr-abs-not-working/
Thanks for your answer however now I'm out of idea...
I have performed the following tests :
- continuity test between the wiring of the abs pump and the abs ECU
- ring abs sensor are in good condition and have the correct number of teeth (46)
- all fuses are ok
- tyres are globally in same condition; is within +/- 10mm
- I have electrically disconnected the abs pump to test it :
* relay are ok (80 ohms and I can "hear" them when I powered them)
* solenoid valves seems ok (4 ohms or 8 ohms and consummes 1.5A or 3A; it will depends if it's an inlet or outlet)
* the abs motor is working
My questions :
- I have a front limited diff slip, is it possible that's making some trouble with the ABS ?
- should I open the abs pump to check the valves ?
- should I go for new tyres ?
- where can I found the software to use with nissan consult to connect to the abs ECU (so that I could log some infos)
Any other idea maybe ?
Thanks for your time
so I have bleed the entire system and the wheels are still locking
I have dixcel m or z type brake pads (I dont know if that could be an issue somehow )
I have order a consult 1 we will see
if I am still getting into trouble I will change the master brake cylinder, abs pump and abs control unit ...
best regards
I finally got a (german) consult
I was able to do the active test with success (meaning the abs pump should be ok)
the wheel data seems to be ok too, they are between +/-1kmh between each other and they are matching the real speed.
I was not able to do the self diagnostic with the consult; I might do something wrong in the process I guess (see picture)
Edited by bigboss59400
I'm suspecting some solenoids being blocked as my wheels are still locking (my feeling is it seems to be the front only ) so I will dissasemble the pump
I have made a test this morning (7am at 1 degre; the road was dry but we some humidity on it; sorry I don't get the english word for it )
you can clearly see from the picture that my abs control seems to react correctly !
if the solenoids valve are in good cobdition, I will put everything back to stock :
  • no winter tyres
  • OEM pads
  • new flexible hoses (avionic )
  • new brake master
thanks
So to conclude,
My assumption was false, based on the curves I provided we can see that the wheels has locked but the ABS release some pressure to unlock them...
Replacing the winter tyres by some regular tyres give a much better feeling too (but I don't think it was necessary)
So at the end, a bleed of the system + some cleaning on the calipers (with a lot of WD40) seems to have done the trick....yes it was such simple
French test has been passed with success this time
I can finally drive legally in a few weeks hopefully
THanks for having a look into my problem.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
