on a minty nur 34 with a power fc his factory boost solenoid (the oem one fixed to strut tower) was open at the pointy end to atmosphere. No tube. No aftermarket boost controller.
mine, whether electrically connected or disconnected sucks a pulsing vacuum through that end at idle. It seems to make a slight difference to idle (open to atmosphere vs not)
is a factory boost sensor supposed to leak vacuum? is it normal to have it open to air?
Factory RB26 boost control solenoid is normally closed mate, so it's not leaking anything to atmosphere at idle. Standard setup opens when activated and vents in front of turbos - completely different to a Mac valve setup.
thats right.
however if you pull the front hose off at idle at least mine is sucking a vacuum like in rhythm. I can feel it. so is it broken? (it is new). It doesnt screw up idle like removing the other hose to it does though.
and why would this beautiful nur pfc have it open to atmo? maybe there was a hidden boost controller and this was not connected? would be news to the owner though.
Edited by syd_gtr
a) it isn't my car with the disconnected hose, I was curious if this was common.
b) I like to know how things work in detail. stock, the solenoid is normally closed, is it also slightly leaky?
perhaps it is better not to create any topics at all on sau - since everything has been asked before even if it can be difficult to find the exact reply, and of course there is a manual to refer to if one doesnt want to know the whys of something.
Skip to 6:00, it explains how the OEM boost control works. The "pointy end" I assume is the outlet that normally goes to atmosphere. In an RB26 it vents to the rear turbo closest to the firewall before the compressor, but after the MAF. The RB26 OEM boost control is a fixed duty cycle output on the solenoid, it doesn't seem to have any form of closed loop control or special intelligence. I've unplugged the wires to the solenoid on my car for now to run wastegate boost and there's not even a CEL if that tells you anything.
As for why someone would do such a thing frankly I have no idea. It's entirely possible it had an aftermarket boost controller at some point and someone ripped it out prior to sale with no real intention to reverse the modification in a clean way.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
