Hi guys need a huge help from you guys identify  a issue with my skyline r33 series 2
My issue is
My spark plug keeps getting fouled
Car starts idling  and misfires  but when I put new plugs in it's alright for a day
I just installed new standard block  and head
I have attached  a video of how it idles now
Any help will be appreciated thanks in advance guys!
https://www.sau.com.au/forums/topic/482246-issues-with-my-r33-skyline/
4 minutes ago, krishyy7 said:
The block and head is new just got put in last week
As per your first post. That's not new info.
Also it's a weird thing to say. I think you mean to say the bottom end is rebuilt? It's not a new block is it?
Plugs foul by either runing rich,  burning oil or less likely too cold heat range.
Also to add to that your breather setup is wrong and atmo blow off valve with maf sensor is not good. Both will  draw in umeterd air at idle but that makes it run lean, so not really related to the fouling problem.
What injectors are you using? Did you happen to change them or other stuff when the new engine went in?
3 hours ago, krishyy7 said:
The block is new just got put in last week
Yes, hence why I suggested that the rings were not bedded in properly. There is a procedure to make a new engine work properly. If you do not follow it, you will glaze the bores and you can forget about it every being any good after that.
7 hours ago, krishyy7 said:
Thanks Ben for the responds
Umm can you walk me through the proper step for the breather and the bov
What do I need
I'm using the standard ones purple blueish ones
I changed new cosmetic headmaster and arp  studs also all new valve seals
No mate, I'm not going to type out info that is all over the place, but I will say your options are either factory style breather system (with oil seperotir if you like) or completely open to atmosphere. It can't be open on rocker and still be connected to pcv.
Bcpr6es for plugs. What are you using?
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
