Has anyone heard of or tried Mertop Racing Products > https://mertopracing.com/
They're fabricating/ manufacturing intake and exhaust manifolds for a few car manufacturers, including Nissan.
Wondering if anyone has tried their stuff, especially on RB's? I've ordered a front-facing intake, not for any performance gains but mostly asthetics. I'm awaiting shipment so haven't yet seen the finished product and quality. Fingers crossed
https://www.sau.com.au/forums/topic/482682-mertop-racing-products/
Yeah wouldn't even bother, be same quality as all the other linglongcheap stuff.
Performance will be worse especially low and mid range. Done back to back testing on Dyno.
Seen a few of these style manifolds either require more matching of flanges or split under pressure.
This is the only inlet intake most people should be using https://plazmaman.com/product/rb25-r33-inlet-plenum/
I have used standard and genuine greddy manifolds and the plazmaman is the best option.
  • 4 months later...
UPDATE (for what its worth):
My experience with this company was not ideal but somewhat surprising. I ordered a Forward Facing plenum with fuel rail and throttle body from a local 3rd party who controlled all the shipping and customs clearing. I'm not entirely sure if some of the problems with my order were down to the 3rd party or Mertop, themselves. Anyway, here's a rundown:
Part took all of 5 months to ship. I ordered the part in black powder coat with a blue anodized fuel rail. The part arrived polished with a black powder coat fuel rail :facepalm: However, to my surprise, the quality on the welds looks exceptional (I mean, its a visual inspection without using dye-pen or anything, but still looks pretty good). Straightness on the mating surface is almost there but not perfect. It was good enough for an experienced builder to look at it and tell me that the gasket will take up that play. It was really about 0.5mm off towards one corner only. The aluminum construction is going to save me so much weight compared to the stock RB25 cast item. Internal welds and construction also could not be flawed, but anyone's guess if it will starve the rear cylinders without seeing any CFD. 90mm throttle body looks ok but I'm no expert here. Fuel rail is just a straight piece of steel with holes drilled in it (what else would you need?). The package also came with some fittings for coolant and water-meth injection if needed. For what I paid, it looks alright visually, here's hoping it holds up under boost :fingers_crossed:
  • Like 1
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
