Howdy, got a v36 with bad engine knock (tin can rattle sound)
I've gone to a couple of western suburbs mechanics and they brush me off.
Main north nissan replaced spark plugs and said they adjusted the timing slightly, no luck.
Can anyone recommend a place that'll help?
Western preferably, but really i'll take it anywhere.
https://www.sau.com.au/forums/topic/483014-v36-engine-knock-repair/
He'll hate me for it, because he doesn't like dirty Renault motors, but take it to Fours'n'more. He'll take a proper look at it and hopefully work out whether it's a buggered lifter, VCT solenoid/actuator, timing chain guide, f**ked bottom end, etc etc.
They're at Pooraka, but that's only 15 minutes up the road.
  • Thanks 1
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
