OK can someone tell me what the two rb26 kits are rated at on this site i think its 800ps for the frist one and 1200ps for the next is correct and are these figures at the wheels or engine
http://xspeed.dreamhost.com/catalog/produc...products_id=330
  • Replies 47
I think you might find that it's not just the crank that gives the extra stoke but also the combination of the piston height and conrod length.
The displacement was messured and was found to be just over 2.7ltr.
I'll have to check whether my rods a standard length or not.
Regarding compression, both my head and deck where milled to accomodate the setup the mechanic is seeking.
I think you will find that it is the crank, and crank only that affects stroke. Pistons suited to stroker cranks will measure less form gudgeon pin to crown to avoid making contact with the head / valves and meeting the desired level of compression. If you have a standard crank and you increase the rod length by say 2mm, the piston will travel 2mm higher at tdc (and would require either a sandwhcih plate or very thick head gasket) but remember it wll also be 2mm higher at bdc. Using your volumetric equation the capacity will remain unchanged. It appears with the kit you have purchased that your gain in capacity is due to the O/S pistons only.
A couple of useless things on Jap stroker kits
1) they all use the standard length rod
2) the difference in the "cheap" low horsepower kit vs the "expensive" high power kit is mainly the pin size(21mm std vs 22mm "SPL").
3) Merli's running big block chev pistons in his new motor to give him a displacement of 8 liters.
Fact or fiction?
Goddammit DoughBoy, you weren't meant to tell everyone that! RB80 > RB30 with RB26 Head :wassup:
And MrCharms, I only resort to smart-ass comments when I have to repeat myself 4 times, only to be ignored blindly and be replied to with completely wrong information over and over again.
There's only so many times I can try to tell you what's really going on with your engine (based on information you've supplied to me), before I give up and try to take the piss hs.gif
In any case, refer to my volumetric measurements on the first page, you're making just over 2650cc, which bumps you up to 2.7 Litres :D
P.S. If you sat down for a minute before replying and visualised what goes on in a piston engine, you'd quickly realise that crankshaft design is the ONLY thing that will effect stroke length. It's pretty simple when you think about it :D
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
