On 7/19/2022 at 12:44 AM, GT351 said:
My son has a r34 rb25, the afm was removed and cleaned with brake clean and replaced. The car will crank fine now but no spark or fuel. Any ideas?? tia.
I'm not even sure the RB ECU looks at the MAF sensor when cranking. Verify that the ECU is getting ignition synchronization by checking whether it emits an RPM signal.
how do I do that?
On 7/19/2022 at 4:48 PM, joshuaho96 said:
It is considered to be OBD1
Whilst being entirely proprietary. The protocol is called Nissan Consult. It's Nissan's own serial diagnostics interface and protocol, only used on Nissans. But any good general purpose scan tool should be able to do it.
