Good morning folks, looking for some help on how to treat my new Endless Brakes.  I recently upgraded my bcnr33's brakes to Endless Racing Mono 6.  All was good until I washed my car and parked it overnight and drove it the next day to work and the brakes felt like the rotors were warped shaking about and the pedal pulsing.  I took a look and found these rust spots on the rotors as shown below.  It looks like where the pad meets the rotors, rust formed overnight.  I spent a week daily driving for 250kms, doing hard braking as often as I can when the opporutnity allowed.  It got better but still the rust spots remain and the pedal pulsing remains.  It's been humid here in Japan so it must've rusted bad overnight.  Anyone have experience with this?  I'll keep pounding on the brakes whenever I can but I feel i've done that enough.  My pads are endless street spec so not too aggressive.
I was thinking about hitting the rust spot with a flex-hone but don't want to do that if I don't have to.
If anyone has any advice, I'd appreciate it.  Thank you!
P.S. The last photo is before the rust occurred just to show off how beautiful the brakes are.
Info on the brakes: https://www.endless-sport.co.jp/products/brake_caliper/index_RacingMONO6.html
Remove pads. Scuff them back on some very flat, slightly rough but not too rough concrete, put them back in and attempt to bed them in again. If that doesn't work, discs off, onto disc lathe and give them a little skim. As well as another scuff of the pads.
Dang, I was hoping just hitting the spot with a flex-hone would work.  That means I gotta go to a shop cause Tokyo living means I'm in a tower with a vending machine parking lot and no place to do that kind of work myself lol.
Thanks for the guidance.  Surprised this happened in the first place.
Gotta be careful with brakes when it comes to washing cars unfortunately. I'm surprised that hard braking didn't clean the rust off though.
It's just strange because I've washed my car 100 times and this never happened before.  The car is parked underground as well so I don't really get what happened.  We did have some pretty serious flooding/rain before the wash and it was humid as heck but still.  I did park it like right after washing though.  I'm also disappointed that this happened since the brakes were ¥¥¥¥¥¥¥¥
It's fixable, just get the rotor and pads scuffed/cleaned off with some sandpaper. Annoying but I wouldn't bother with new pads/rotors just yet.
Edited by joshuaho96
That's the plan.  No way I'm giving up on these new expensive rotors lol.  These are times I wish i had a house with a garage to work on a car.
Thanks man and I gotta get an update from you on your progress.  Next for me is a Nismo intercooler. I'm still hoping for a California plate in the future...
I talked to Nismo and they said I need to go do some more back-to-back high speed hard braking. If that doesn't clear it then I need new rotors and pads which would suck.
I think the advice on some really hard braking to get the brakes stinky hot is good.
The advice to buy new pads and rotors is bad. If getting them hot doesn't work you need to just get a mechanic to skim the discs as said above. I'm pretty confident the rotors are warped, that's why the surface rust isn't getting wiped off straight away.
BTW it is perfectly normal for a brake disc to grown surface rust overnight if it gets wet, it gets wiped off as soon as you use the brakes
Sounds good I'll attempt some hard braking back-to-back from high speeds.  It's actually really hard to do that in tokyo area but i'll find a way lol.
The brakes setup is pretty new, like no more than 8,000 kilo's on them.  I've definitely encountered surface rust from washing the car or rain, but nothing like this.  It was like flooded the same weekend I washed it though and drove through some pretty deep puddle but thought it would have dried out by the time I got home.  I hope the rotors are not warped.  The rust is only where the pad met the rotor overnight.  So when it hits that lifted rusted spot, you can hear it and feel it when braking...
Thanks for the advice.  It sounds salvageable!
Edited by Hella_GTR
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
