Sooo i saw a post from 2019 regarding these however nothing recent, has anyone bought and installed one of these? if so share the experience and would you recommend?
Also any other aftermarket systems you have replaced the head deck with?
https://www.sau.com.au/forums/topic/484100-v36-telsa-screens-from-alibaba/
You could get the android tesla screens - they are getting better with the newer versions since they use newer chipsets etc. You may get issues installing them if they send you a wrong harness and in some cases some features may not work. I can understand wanting to change. I went through a year of looking to change mine but decided not to after seeing how much f**king around it needed (this was when these were first released and many people were doing testing and talking to the manufacturer to get different things programmed for different variations of the car in USDM/JDM etc.
The module currently in my V36 is from Naviplus. It's local and so far my AV guy have had good support from the guys at Naviplus.
https://www.naviplus.com.au/online-store/Nissan-V36-J50-Skyline-Apple-CarPlay-&-Android-Auto-Integration-p96711064
The only other thing I can say is the build quality was not great and did not look good. A few people I know ended up wrapping up the plastic trims etc. but your car, your call.
Edited by colin.ssc
I am NOT recommending this unit, and only know what I can see from the link below. I only post it because I have not seen anyone mention it.
Things to note:
  • Its an Australian based company
  • The unit is $519, but once you add the min expected things such as a reverse camera, its $715 (scroll down) before installation
  • It basically looks to be an android phone/tablet, and 3GB RAM is not a lot.
Another place to check about these would by an android forum such as:
https://forum.xda-developers.com/m/teyesaustralia.11474311/
https://forum.xda-developers.com/f/android-head-units.4267/
Personally, I have my center screen translated, and use my phone for very good Audio (possibly not installable on this unit?), and navigation (Waze, which could be installed, but I am rooted/jailbroken and have modified it to remove the ads ect etc) and also ODBII over bluetooth. I also kind of like having a second screen (ie the phone) purposefully for Nav. And it kina looks a little bit like a tack-on with sticky tape.
Edited by Vee37
I recently installed one of the 12.1 tesla screens in my 08 V36 (Nav, bose, rev & side cam) that I bought on Amazon (SHRZR i think the brand was). I msg'd the seller first with my car details and they sent me extra harnesses, but no instructions.
The 6gb of ram and 128gb internal storage is excellent, nothing lags, I've installed poweramp, waze, Newpipe and Novalauncher plus widgets etc... All very snappy. Installation was a fkin pain, but I think that was mostly my inexperience. It was hard to find support/information on it because there are SO many different chinese headunits. The firmware was barebones and missing features listed in the add. But installing Novalauncher fixed pretty much everything software wise except one thing. This unit aquires the time by gps or phone signal, which ever is available. Both antenna are weak. So on a rainy or cloudy day, it can take almost 10 minutes to display the correct time & date lol.
Here's the one i bought, I left the 4 star review.
https://www.amazon.com.au/gp/product/B09FGR8PKF/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  • Thanks 1
  • 3 weeks later...
  • 1 month later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
